My Frigidaire's icemaker recently started leaking, and now that I have replaced the 3-solenoid valve pack & the icemaker itself, I notice that the cause of the leaking is the water dispenser in the door. Anyone have any idea how getting water from the door dispenser causes water to also go to the icemaker causing it to overflow? Water sometimes also leaks from the dispenser in the door on its own.
Thanks ![]() |
Most likely you have the diodes in the wiring harness to the water valve, when these go out it will feed both sides of the valve at the same time when either of them activate....need the complete model number to try and pull up a wiring diagram to see if your frig has these, sounds like it does..
Thanks for the info, wish I had known of that possiblility before I changed the valves and the icemaker. Model # FRS26R2AW5.
Thanks |
| GE Monogram side by side leaking at bottom right of door? | LosGatos | GE/Hotpoint | 4 | May 28th, 2008 07:53 PM |
| Frigidaire FRS26ZNH side by side icemaker quit | N.H.B | Frigidaire/Electrolux | 2 | August 22nd, 2006 08:50 AM |
| Frigidaire side by side leaking on FF side | sacju | Frigidaire/Electrolux | 3 | October 24th, 2005 11:25 PM |
| Maytag Side by side leaking | jrc0109 | Maytag/Magic Chef/Admiral/Jenn-Air | 3 | October 16th, 2005 10:11 PM |
| Water leaking from side by side Frigidaire | goldmonkeyking | Frigidaire/Electrolux | 3 | August 23rd, 2005 04:03 AM |
