Old November 17th, 2007, 11:33 AM
Krista Huntley is on a distinguished road
Default Dryer sparked & now doesn't come on.
We replaced the glide on a Frigidaire FSE737GES1. Ball that sticks out back was grinding so we lubricated it. It helped for a couple loads and started again. We then tried lithium grease to lubricate. Then the dryer would turn on automatically without the start switch. Then after a couple times it sparked and won't turn on at all. What could be the problem?
Old November 17th, 2007, 12:59 PM
I can't seem to find that model number. Could you re-check it for me. Where were the sparks? If it's electric, check the circuit breaker.
Old November 17th, 2007, 04:06 PM
I'm sorry, model number is FSE747GES1
Sparks came out underneath lid on top of dryer. Checked circuit breaker and turned it back on. The heating element comes on when turn on dial.
Old November 17th, 2007, 05:11 PM
Sounds like the heating element is shorted to ground. Thats probably where the sparks came from. You can check it with a meter by going from the heating element to ground and see if you get a reading. Or you can take it apart and look. I would think with the sparks it will be obvious.
Old November 18th, 2007, 09:42 AM
Could the sparks have shorted out/ruined the starter switch?
Old November 18th, 2007, 09:45 AM
Possibly but I doubt it. The sparks could of taken out the thermal fuse though.
Old December 22nd, 2007, 07:52 AM
I replaced the bearing on this same dryer. It came with a tube of lubricant, but no instructions where it needs lubricated. It is high temperature Frigidaire lubricant. Dryer model FSE747GES1. The dryer works, but bearing is making a lot of noise. Where exactly does it need lubricated?
Old December 22nd, 2007, 08:42 AM
Hi Krista,
FSE747GES1
Diagram#1 Part location#12 is your white plastic cup style bearing, the lubricant goes in their, use alot to fill that cup somewhat.
Erratic Dryer Behavior (MDE5500AYW) Lawrence Maytag/Magic Chef/Admiral/Jenn-Air 9 February 12th, 2007 04:20 PM
GE Electric Dryer runs but no heat vdrsolo GE/Hotpoint 1 September 27th, 2006 12:44 PM
New Dryer keeps tripping circuit breaker wabeeth Sears Kenmore 2 February 14th, 2006 07:40 PM
Whirlpool Dryer gets Warm not Hot, Takes long to Dry jnicosia Whirlpool/KitchenAid 4 August 19th, 2005 08:48 PM
Kenmore 90 Series Gas Dryer Problem HomeRepairGreenhorn Sears Kenmore 9 March 15th, 2005 01:02 PM
