Results 1 to 2 of 2
Thread: top load washer squeak squeal during spin
    aclowery is offline Member
    Aug 2005
    Default top load washer squeak squeal during spin
    Have a glgt1142cs1 new combo unit. While spinning there is a very load (90-100db)squeak, muck like fingernails on chalkboard. The unit is brand new. Called warranty service and the tech replaced the snubber ring. The snubber ring looked like a 2 inch band made into a ring with rubber on top and bottom, about 9 inches in diameter (saw he put some grease on it too.) Fine for a couple of weeks, then its back again.
    Any ideas? Is there a snubber ring from another manufacturer that works better possibly?
    thanks so much!
    Art
    Oct 2004
    Nope.
    Common problem.
    No rubber, teflon like pads built into both sides. Should also use no grease.
    New ring, arrow up, clean base and suspenstion bottom with alcohal like cleaner, replace snubber ring, set an off balanced load and let spin for 2-3 minutes to work some of the teflon from the ring onto the mating surfaces. That is the basics of changing the snubber.
    http://www.applianceaid.com/
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
  1. Maytag top load intermittent no spin
    By donPop in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 29th, 2007, 11:46 PM
  2. Replies: 9
    Last Post: May 14th, 2007, 10:40 AM
  3. Kenmore Front Load Washer Spin Noise
    By jhooper in forum Sears Kenmore
    Last Post: April 24th, 2007, 07:48 AM
  4. Maytag Top Load, oil leak under washer
    By Robert Pearson in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 25th, 2007, 11:38 PM
  5. Top Loader Washer VERY Load during Spin
    By mattscott2001 in forum Washers
    Last Post: May 21st, 2005, 08:35 PM
