Old August 30th, 2005, 02:22 PM
tpmdtm is on a distinguished road
Smile Low Freezer Temp and Water leak
I have a model FRT21TSG. About 7 years old. The freezer is hovering around 25 degrees. Needs to be around 0 if I am not mistaken.
Also, water accumulates under the crisper drawers in the refrig.
Not quite sure what to do. Don't quite see how water can get inside the refigerator if the drain tube is blocked.
Any insight would be appreciated. Thanks.
Old August 30th, 2005, 04:58 PM
Can you re-check the model number, should be a little longer than that. Usually found on a label inside the refrigerator compartment.
Old August 31st, 2005, 07:39 AM
Default Model Number
Unfortunately that is the model number as it appears on the sticker inside the refrigerator. Hmmmm? I got it at sears, i wonder if they mess with the numbers for some reason. Anyway, regardless of that, do you have any idea about possible causes for the water accumulation under the crisper bins and the high temp in the freezer. Seems like they must be related.
I keep reading that the water accumulation is probably due to a clogged drain tube. I took it apart and noticed that the pan that the water drips into (or should drip into) is dry. But while I was looking at it, one drop came out of the tube into the pan. I wonder if under normal circumstances, the pan would always have atleast some water in it. If so, mine isn't draining properly. But if it is normal for the pan to be dry between defrost cylcles then maybe mine is normal.
Also would a drainage problem effect the temperature, in other words is it reasonable to assume that the two symptoms are related?
Thanks for your help.
Old August 31st, 2005, 09:55 AM
Managed to find something similar, Friggidaire top freezer. Remove the back panel of the freezer and check the defrost drain. If this is blocked, water will run down through the vents and end up in the bottom of the refrigerator compartment. Also check your evaporator (in the back of the freezer) for an even frost pattern whlie you're in there. May all be one issue, may be two.
FRS23KR4AW2 keeps freezing my" Filter Housing "causing water leak. zog Frigidaire/Electrolux 1 June 1st, 2007 09:04 PM
Freezer temp changes on Kitchen Aid Superba Pete V KitchenAid 3 April 9th, 2007 12:34 AM
Water temp circuit problems stuntdouble Amana 1 October 23rd, 2006 10:45 PM
Duet Washer Water Temp. Settings lb379621 Whirlpool/KitchenAid 1 June 23rd, 2006 04:33 PM
Water, ice & cooling problems hootowls Amana 20 December 13th, 2005 01:16 AM
