Old February 6th, 2008, 03:09 PM
dave01978 is on a distinguished road
Default door not closing right
Ok i have a frigidaire fwt449gfs1 and I just installed a new latch to replace a broken latch, the old latch pn is 131279000 adn the part i ordered was 131279001 according to the site, that is the replacement part # it latches ok, but the bottom of the door needs a little pressure to keep it running any idea's? I checked the rubber gasket around it and appears to be sealed still.
Dave.
Old February 6th, 2008, 10:11 PM
Hi Dave,
Thats the correct one for your model, here it is:
Manufacturers Part# 131279001
icon
icon
icon
You may need to change the latch/lock assembly:
Manufacturers Part# 131888900
icon
icon
icon
Old February 8th, 2008, 05:42 PM
Thanks Jake,
I just ordered it, I hope that fixes it, as it seems its lower thats not sealing properly, but i am hopefull this will fix it, I am so happy to have found this site.
Dave
Old February 8th, 2008, 10:16 PM
Sounds good Dave, let us know the outcome.
Old February 16th, 2008, 09:09 AM
ok i installed the new door lock kit, the counterweight i had did not have a bump, so i didnt need to replace it per the instructions, now i had 1, 2-pin connector left not sure where this goes, i checked 3 times and still cant find it, is it not used on some models? I checked the machine, it fills, but it doesn't spin now, I rechecked the wiring, but wondering if you have anything specific I should be checking.
Dave
Old February 16th, 2008, 09:59 PM
Ok, then its possibly your motor speed control board thats bad as well, check this thread for more about it:
Kenmore 417.29052990 frt loader diagnostic procedure
You should have the service sheet for your washer, its located inside the bottom of your washer in the front after you remove the access panel, on the left inside wall.
Here's the motor speed control board for your model:
Manufacturer's Number: 131725300
Old February 17th, 2008, 08:37 AM
Thanks for the help jake,
I unplugged the connection into the speed control board, then reconnected one last time, and now its working, thank you so much for your help, and for your site, you probably saved me a few hundred bucks,
Thanks again, you are awsome.
Dave
Old February 17th, 2008, 09:25 AM
Sounds good Dave, glad you got it fixed.
Old February 17th, 2008, 09:40 AM
ok jake, I thought i had it working, it does the slow spin only, does not ring the clothes dry at all, now i have a question on the instructions it says for model with serial #xc703 and lower to rewire connection on the harness contector, that goes to speed control board (i think) but the SN i have is xc93439211 and it says SN above skip that step which i did. I just want to make sure i am reading this correctly.
And i did have one extra 2 pin connector with a white and red wire.
anything else to try before trying a new speed control board?
Dave
Old February 17th, 2008, 02:57 PM
Yes, everything with your wiring seems correct, so its likely your speed control board thats bad.
Also check your wire harness connector were it plugs into your motor, I've seen the little metal pins either burn out or back out of its slot.
Jenn Air oven door not closing wakeappliance Maytag/Magic Chef/Admiral/Jenn-Air 4 October 21st, 2008 03:19 PM
Freezer Door pops when closing ME2 Maytag/Magic Chef/Admiral/Jenn-Air 4 August 30th, 2007 09:24 AM
Kenmore side by side door not closing properly shuntoo Sears Kenmore 3 August 14th, 2007 06:19 PM
Ice dispenser flapper not closing bfollett GE/Hotpoint 7 July 4th, 2006 08:37 AM
