Old April 23rd, 2008, 07:44 AM
CJ51974 is on a distinguished road
Default Frigidaire Crown Series Squeeling
I fix cars not dryers so im new with this, my frigidaire crown series not sure of model but the only numbers on the dryer was frigidaire crown series 131551500. Its making a loud squeeling, seems like it gets louder then quieter in a pattern every second, almost like a certain spot on the drum is making the noise. I removed a small square in the rear lower lt corner and removed a pulley freeing the belt. I then ran it and there was no noise. Im not sure if its the belt, pulley, or somthing with the drum, I also dont know how to remove any other panels to get better access in there. Any help is greatly appreciated, attached is a link with photos of the dryer and where I am at. Thank you.
CJ51974/dryer - Photobucket - Video and Image Hosting
-Adam
Old April 23rd, 2008, 09:00 AM
The model # is F31C436ES0
Old April 23rd, 2008, 09:20 AM
I can hear the sound when I took the pulley off and manualy spin the drum. I just dont know what I need to replace in there, a bearing or guide? Also some information on how to get to the part and replace. Thank you
Old April 23rd, 2008, 09:35 AM
ApplianceJunk's Avatar
You need to replace the rear drum bearing.
It's a cheap and simple job. Being you can fix cars I can tell you now it's not going to be a bearing like you think it maybe.
Lift the top of the dryer up from the front. There are a couple clips in front that you can push in with a putty knife to release the top.
Then remove the front of the dryer so you can pull the drum out.
You will need to lift the drum up about a inch and then pull it forward.
Once you have the drum out you will see just what the problem is.
Old April 23rd, 2008, 09:38 AM
There are also some pads that the front of the dryer drum ride on.
Now is a good time to look at them too while you got it apart.
Old April 23rd, 2008, 10:02 AM
done, I pulled that bearing. Its like a plastic surround, and then like a bulb which is connected to where the drum bolts. Its all full of crap. The plastic guides look ok, I did crack one of them off by accident tho. I want to replace that bearing, the guides, and the belt while im in there. I dont replace that bulb/drum mount metal piece, just the plactic bearing race correct? Also I was going to use axle grease, but is there another grease I can put in there thats better? Anywhere local I can find these parts rather then ordering online? My zip is 32084. Thats for the help
Old April 23rd, 2008, 11:22 AM
I use this kit that has everything you need it in.
http://www.appliancepartspros.com/pa...gram_id=376346
It's a common kit and any of the local appliance repair shops should stock it.
Old April 23rd, 2008, 11:43 AM
Thanks for the help. I checked and there was 1 local supplyer, however the guy was charging double the price of the stuff online. I ordered online but I order piece by piece and it was cheaper. The only thing i dont have is the lube. Is there a type of lube you would recomend that I could just buy at the store. I have in the garage axle grease, white lithium grease. Any of those work. Again thanks for the quick responses and help.
Old April 23rd, 2008, 12:48 PM
Not really sure on the grease. I have only ever used the stuff that comes in the kit. I don't think the grease is anything special. It does not turn that fast and I don't think it gets all that hot. It is next to the heater, but then the part is plastic too.
Old April 23rd, 2008, 12:57 PM
thanks, ill just use axle grease
Frigidaire SxS Gallery Series Ice Problems hunt_ak Frigidaire/Electrolux 5 September 23rd, 2008 01:45 PM
Frigidaire Galleria Series GLD225ORD Leaking Karbon Frigidaire Brands Forum 0 October 15th, 2007 07:21 AM
Frigidaire Gallery Professional Series - Water bottom fridge when water line is on echaland Frigidaire/Electrolux 2 July 18th, 2007 10:26 AM
Frigidaire Crown Series Model FDE323RGS1 Won't Run (Buzzing Sound) PMAC Frigidaire/Electrolux 4 December 13th, 2006 07:01 AM
Frigidaire Professional Series alex Frigidaire Brands Forum 0 January 28th, 2006 03:19 AM
