Old June 6th, 2008, 05:02 AM
ronaldvignali is on a distinguished road
Default fridgidair FRS26LF7DS5 runs but no cold air
Jake, just purchased a used FRS26LF7DS5 fridge knowing it needed repair. I was going pay to have it repaired but read that it may be under warranty. The manufactuer date is 12-04. Am I in? Next, the problem is this; every thing runs and sounds fine but after removing compressor access cover I found a metal (steel?) tube at left of compressor hanging down from hole near reefer lines come through. While powerd up and running this tube leaks light oil and air or gas preassure. What is it? I can send pics if you need. Thank you, Ron.
Old June 6th, 2008, 06:13 AM
Hi Ron,
First, send a pic and lets see exactly what that is. Second, tell me where in Jersey. I'm from Jersey, Hunterdon County.
Old June 6th, 2008, 11:45 AM
Hi Redbeardnmt, we are in atlantic county near atlantic city. Here are 2 pics, notice tube on very left. Oh and sorry took so long, had to work.
thanks
fridgidair FRS26LF7DS5 runs but no cold air-fridge-003.jpg   fridgidair FRS26LF7DS5 runs but no cold air-fridge-004.jpg
Old June 6th, 2008, 01:18 PM
OH NO!
Someone removed your filter drier assembly.
They won't warranty it because someone removed it.
Your looking at big money to have a tech. come and fix it.
Hope you didn't pay alot for it.
Here's the filter drier part thats missing:
Manufacturer part#5303305677 is RepairClinic item#632247
5303305677
Old June 6th, 2008, 01:59 PM
Yep, the filter dryer is gone. Jake's right about the cost and one other thing, if it's been open for any length of time it's going to need a sweep charge first to get any contaminates out of the system.
Old June 6th, 2008, 04:37 PM
Ok, no problem, 8.50 for the part then how much should I pay for labor and sweep charge? Also, I can save on tech's visit and transport the unit myself. Paid 50.00 for it.
thanks, Ron.
Old June 6th, 2008, 08:04 PM
That's going to be a hard question to answer. I'll try to explain why. First it depends on the company or service tech on what pricing they use. 10 to 15 years ago everybody used the hourly, time there, time charged pricing system. Most appliance service companies charged anywhere between $40 to $60 per hour plus the service call/diagnosis fee. Certain repairs on the sealed system usually had a fixed price that factored in the cost of welding supplies, access valves, refrigerant, ect, ect. We charged $450 for compressor replacement and $300 for a leak repair. I've found that to be a pretty standard price across the States. Now most appliance service companies use the flat rate system. I use the Major Appliance Service National Price Guide (MASNPG). It lists every appliance by Brand and has a flat rate for each repair. I looked up Frigidaire-Refrigerator-Leak Repair. It lists the price $421.10. If you bring it into the shop, subtract $69.95. In your area if you call four different service companies you'll probably get four different prices. A sweep charge is basically another leak repair. After the system is repaired, you run it for a while then take out all the refrigerant, change the filter again and re-charge it with new refrigerant. This removes any particulates and moisture trapped in the system. It's done when the compressor is a burn out or the system has been open for a while. Not every company does this however. Some think it's unnecessary. If not done a problem may not show up, or may not show up for several months or even years. When it does it's usually a restriction at the filter dryer. (the part you're missing). The best way to go is; call around for some prices and see what they say. Ask about their warranty on that type repair. A very small leak might not be noticeable for months.
Sears 1999 253.70137990: Refridg Not Cold SteveH Sears Kenmore 3 March 3rd, 2008 09:42 PM
Fridge SXD26VW cold, warm, cold ? chinup7 Amana 4 November 30th, 2007 10:16 AM
Fridge Not cooling but frezzer is cold (help) D33ZZ Refrigerators & Freezers 1 July 31st, 2007 09:10 AM
only cold air in dryer..help..lol Gwen Sears Kenmore 1 July 22nd, 2007 09:02 PM
Kenmore Freezer runs but not cold wetstein Sears Kenmore 1 October 7th, 2005 10:52 AM
