Old June 10th, 2008, 12:49 PM
eagles_fan is on a distinguished road
Exclamation Frigidaire FRT21KS5A Water Under Crispers & On Top Shelf
Hello,
We have a 7-year old Frigidaire FRT21KS5A (freezer on top, no ice maker or connected water supply) refrigerator that has suddenly started to collect water under the crispers. I toweled up the water last night and by late this morning a substantial amount was there again.
Yesterday I looked for leaks, or signs of water running down the back or sides, and saw no sign of that; but I've noticed that there seems to be more moisture on inside surfaces (e.g. on containers, shelves, etc.) than I remember used to be the case.
I also just checked a few moments ago and saw a trail of water droplets down the inside back of the fridge running to the bottom now, and just found some water on the top shelf. I also just noticed some water dripping very slowly now from the back of the top console (i.e. behind where the light bulb is located) where there is some plastic tubing and white styrofoam visible. I wish I could be more specific but I don't know the actual terminology for what I'm looking at. :-)
When I went to the Frigidaire site (as noted on a post or two that I found), it suggested I call to schedule a service call for a part replacement. Could this build-up be due to the need for a replacement ferrule seen at the URL below?
http://www.repairclinic.com/referral...=1265&N=919180
I'm not sure if this part is right for our model, or if this might be caused by something else. Any help would be very greatly appreciated.
Thank you!
Last edited by eagles_fan; June 10th, 2008 at 12:53 PM.. Reason: Changed title to be more accurate.
Old June 10th, 2008, 02:18 PM
First check your defrost drain line that runs from the back of your console#17 inside the refrigerator section here:
Take the #58 console screws out, there will be 4, two on each side, then the console#17 will drop down, then you can check the drain hole, were the back console nipple goes into.
You can flush that drain line with air pressure or get something to run down it.
That ferrule part you linked to, is just for when some water drips on the top shelf, but the remainder goes down the drain line, from what your saying it sounds like all the drain water is going to the bottom of your refrigerator under the crisper's.
Old June 11th, 2008, 09:31 AM
Default Frigidaire FRT21KS5A Water Under Crispers & On Top Shelf
OK ...
One quick question: is the drain line that needs air pressure applied to it the clear plastic tubing that I see, or is it the channel behind the black ring (the nipple you mentioned?) at the back of the refrigerator?
Thanks again for your help.
Old June 11th, 2008, 10:20 AM
It should be the drain hole that you see on the inside back wall of your refrigerator were that nipple goes into.
Old June 11th, 2008, 10:24 AM
Excellent! That makes sense. Thanks, Jake.
I'll report back with the results as soon as I can.
Take care.
Old June 11th, 2008, 10:48 AM
Ok, sounds good.
GE GJXRP080B0WW Top Loader, keeps adding water orangeman GE/Hotpoint 3 February 18th, 2008 09:45 PM
Top load frigidaire water level too low? need help362 Frigidaire/Electrolux 3 January 29th, 2007 05:54 PM
Frigidaire SxS water dispenser is dripping water batman Frigidaire/Electrolux 2 June 13th, 2006 10:15 AM
