Old June 15th, 2008, 07:08 PM
joker97 is on a distinguished road
Default Frigidaire Dryer Model GLEQ332AS2 No Tumble
I have a Frigidaire dryer model GLEQ332AS2 and the tub doesn't turn to tumble the clothes. I'm 99% sure it is the motor. When trying to start it just hums. It will turn (and run) if I hold the door switch, press the start button and start the tub spinning by hand then finally quickly shut the door. I think the motor is part 407697 but I'm looking for someone to confirm. The other thing I need is some instruction help on how to get to the motor. Do I have to remove the tub or drum? Or can I get to it from the back? Are there any online instructions with pictures?
Joker
Old June 15th, 2008, 09:35 PM
Hi Joker,
Yes, its the motor thats bad.
The part 407697 is the RepairClinic Item number.
You can order it from RepairClinic or Appliancepartspro, at present its cheaper at appliancepartspro, you can order it from the link here:
The manufacturer's number is here:
Manufacturer's Number: 131560100
icon
icon
icon131560100
Here's a help guide to take it apart to change your motor:
http://www.applianceaid.com/wwf-howto.html
Unplug or turn the breaker off to your dryer first of course.
Frigidaire Dryer Model #FEQ1442CES0-Only turns when selected to no heat griffon Frigidaire/Electrolux 2 July 7th, 2007 11:52 PM
Mystery problem with Frigidaire Dryer jamiedolan Frigidaire/Electrolux 3 April 30th, 2007 10:30 AM
Frigidaire Model FSEC446RHS0 Dryer - Hot but slow to dry! Boozer416 Frigidaire/Electrolux 1 February 10th, 2007 09:07 PM
Maytag Dryer Model LDE712 - Does not tumble. limey1950 Maytag/Magic Chef/Admiral/Jenn-Air 2 August 14th, 2006 06:34 PM
Need parts- 1964 Frigidaire dryer Model DCIF-64 frigidaireman Frigidaire/Electrolux 1 April 7th, 2006 10:23 AM
