Old June 19th, 2008, 04:12 PM
firedogut is on a distinguished road
Angry Frigidaire won't start
my model is FERB7800DS0
the dryer won't start. when you press the on switch it just humms. nothing turns, nothing kicks on. let go of the switch and it won't start.
i have a wet load in it
thanks
Old June 19th, 2008, 06:26 PM
It sounds like you may have a bad motor.
As a test have someone hold the door switch, then push the start button and hold it and at the same time turn your drum counter-clockwise, then release the start button and see if it starts turning on its own.
If it starts running, its definitely your motor thats bad.
Here's the motor for your model in case you need to order it:
Manufacturer's Number: 131560100
131560100
Old June 19th, 2008, 06:36 PM
strange I turned the drum 1/2 a turn each way then closed the door and it started up with out issue.
i've turn in on 10 times now with out issues. any other ideas?
Old June 19th, 2008, 06:51 PM
Yup, your motor is bad.
You'll need to replace it, cause it will do it again in time.
Frigidaire Crown Series FDEB23RGS2 Dryer Won't Start KDYaker Frigidaire/Electrolux 7 May 31st, 2008 09:57 AM
Frigidaire front loader wont start jenbiam Frigidaire/Electrolux 4 November 16th, 2007 04:29 PM
Frigidaire Dryer won't start without a "push" web Frigidaire/Electrolux 0 October 15th, 2007 06:30 AM
Frigidaire LEQ1442ES0 lights up but won't start AukwardPuffin Frigidaire/Electrolux 3 March 4th, 2007 04:41 AM
Frigidaire GLTF2940ES Won't Start strobachyzoo Frigidaire/Electrolux 2 July 17th, 2005 06:03 AM
