Old September 18th, 2005, 01:41 PM
Seal is on a distinguished road
Unhappy Frigidaire front load washer sounds sick
Any help would be greatly appreciated.
We were washing towels when we heard our 4 month old Frigidaire Gallery front load washer (model #GLTF2940ES0) start making a terrible sound. I stopped it immediately. Now when I press start you can here the door lock and then there is a grating/slipping sound. I have tried it on drain/spin and on rinse/spin settings with the same result. The drum spins freely with no sound when I manually turn it. Could it be something caught in the pump? If so, is that accessed through the front panel of the washer or the rear?
Old September 18th, 2005, 03:58 PM
4 months old....call for warranty service.
Old September 18th, 2005, 04:26 PM
Unfortunately I can’t, I live outside the US and the warranty is not covered unless I ship it back.
Old September 18th, 2005, 05:52 PM
AH...remove the bottom panel, pump is right there on the right.
Old September 19th, 2005, 12:58 AM
I'll have a look
Old September 19th, 2005, 03:20 PM
Thumbs up
Thanks for your help Mad Mac.
It's fixed, believe it or not somehow a bra under wire made it's way through to the pump.
Bet you don't hear that one too often :-)
Old October 24th, 2006, 07:18 PM
hitech is on a distinguished road
Exclamation underwire bras in pump
Underwire bras, poly-filled pillows and comforters are not permissable in washers. Hand wash your bras and take the others to the Laudromat. The poly fill in other items can wrap arround the pump like fishline and disable the pump. the wires come out of the bras and go right through the holes in the basket. They can be trapped in the outer tub requiring a very expensive disassembly to get it out or be trap in the pump or even perforate a hose. NO undwwerwire bras is machine washable -EVER!
Jim
Hi-Tech Appliance Specialists
Belt falling off of Frigidaire Front Load Washer cschlete Frigidaire/Electrolux 11 November 26th, 2007 04:45 PM
Frigidaire ATF7000ES Front Load Washer E10 Error nookerdude Frigidaire/Electrolux 3 November 13th, 2006 09:51 PM
Frigidaire Front Load Washer loud sid58ney Frigidaire/Electrolux 7 August 14th, 2006 12:17 PM
Frigidaire front load washer won't agitate or spin bigwilliecrash Frigidaire/Electrolux 1 March 14th, 2006 03:54 PM
Frigidaire FWTR445 front load washer motor Jolendd Frigidaire/Electrolux 4 May 4th, 2005 04:58 PM
