Old July 19th, 2008, 06:22 PM
kbert is on a distinguished road
Default Frigidaire Won't stop ejecting ice.
Hi Guys,
New to the forum, so thanks in advance.
I have a Frigidaire FRS26ZHS The ice dispenser all of a sudden started ejecting ice. I have disabled the front panel, by removing the pc board. I have reinstalled the board, hoping it would reset itself. But no luck. I have checked the mini or micro switch attached to the activator lever, and the switch does work, the circuit closes when activated. So, would it be the PC board? Can someone help me diagnose this issue, so I don't buy parts that are not needed.
Kyle
Old July 19th, 2008, 10:21 PM
Hi Kyle,
There should be 3 more letters and a number after the "S" in your model#. The model# tag should be located inside the refrigerator section on the upper walls or ceiling.
Old July 20th, 2008, 06:26 AM
Hi Jake,
Yes correct model # is FRS26ZSHB0. But to update you, I emptied the freezer last nig turned it off, left it to defrost/thaw out overnight. Put it back together this morning and it seems to be working fine. I will keep you posted on my progress. Thanks
Kyle
Old July 20th, 2008, 10:02 AM
Thanks Kyle,
I remember there was a service flash on this issue a few years ago.
If I recall correctly it was the dispenser control board that was malfunctioning.
Here's the cheapest price I found on your dispenser control board for your model, in case you need to order it:
Manufacturer's Number: 218881801
218881801
frigidaire ice maker leak icemanTO Frigidaire/Electrolux 32 September 28th, 2008 06:25 PM
Frigidaire FRS23KF7AW4 Ice Maker will not stop dispensing ice drparker Frigidaire/Electrolux 3 December 19th, 2007 09:38 PM
Ice Maker Will Not Stop Making Ice - Whirlpool Model ED22TEXHW03 AppMon235 Whirlpool 10 September 28th, 2007 11:42 AM
Kenmore Ice Maker won't stop making ice CC25 Sears Kenmore 6 July 27th, 2007 08:39 AM
