Initial problem was, dryer would frequently fail to start. turning the start control resulted in a buzzing sound. I tried moving the drum manually, and sometimes it would work after that. Eventually after trying various settings, it changed to just a click when the start button is turned. After reading several posts decided it must be the motor so ordered on with overnight shipping. I've install the new motor and the behavior did not change. Even with the belt disconnected the I just got a clicking sound. The motor and blower fan turn easily.
Here is a post some one else described almost the same issue (http://applianceguru.com/forum2/5435.html). I've isolating the clicking sound to a relay or solenoid on the control panel ![]() Several months ago I replaced the solenoids, and belt. So where do I go from here? I'm out $175 for the motor and shipping. I''d rather not buy any more parts I don't need. ![]() Thanks, Paul Last edited by Wiz_222; July 23rd, 2008 at 07:55 PM.. |
Hi Paul,
Thats very strange, I've been repairing appliances for 20 years and never once replaced a control board for a buzzing no-start motor. But like the old saying goes, "just when you thought you've seen everything" ![]() Where did you buy the motor from? Jake
Hi Paul,
Start with the obvious and re-check your wire connections. Check the thermal fuse and door switch. Make sure the dryer has power. Just because you hear the clicking sound doesn't mean it's getting the full 110VAC power supply. It sounds like the control board has possibly gone south.
I got the motor from PartsSelect, (hadn't found your site at that point darn it) I had bought one locally to save time and shipping and when I got ready to install it discovered it was the wrong model. Their supplier was out of stock with an August due date, of the correct model so they suggested PartsSelect. My motor has a three wire connector coming out of the coils of the motor as well as the two or three inch long multi-connector, the local motor didn't. The control board is pretty expensive to replace to isolate the problem. Any suggestions on how to isolate the defective part? Paul |
Paul,
Just to make sure we're on the same page, you got the correct motor from PartsSelect and installed it and it didn't fix it? Did you make sure it was the correct motor part# from the manufacturer? Here's the motor for your model: Manufacturer's Number: 131511900 Jake
Yes the motor I purchased and installed was the same part number, and just like the picture posted. The motor I purchased locally, and didn't install was a different number and didn't have the extra connector that hangs loose shown in the picture. redbeardnmt, said: Start with the obvious and re-check your wire connections. Check the thermal fuse and door switch. Make sure the dryer has power. Just because you hear the clicking sound doesn't mean it's getting the full 110VAC power supply. It sounds like the control board has possibly gone south. I'll do that tonight when I get home. I'm pretty sure the door switch is working correctly, the light is on when extended and goes out when I press it in simulating closing the door.
Paul |
Its not likely your thermal fuse, or it won't do anything at all.
I was trying to locate the a repair manual online for free, but can't find one. I don't know off hand without the tech. sheet which wires on the motor to check, but the repair manual would say. Here's the repair manual for your model: Frigidaire Gas & Electric Dryers Repair Manual ![]() Jake
I checked with a meter and I have continuity across the safety thermostat. I also have continuity across the door switch. I checked the thermostat mounted to the blower housing and there are six wires connected. I do have continuity across some of them. With it plugged in and the top off when I twist the start switch I hear a relay on the control board click and a faint whirring from the timer switch. Since repairclinic does accept returns what would you suggest I order? A control board? Anything else? I could order another motor just to make sure the replacement motor was not defective. I'll get the manual as well. If I follow that link and order more parts you'll get the referral won't you?
Look on the motor switch. The terminals should be numbered. Set your meter to read AC volts. Put one probe on #M4. This is the wire comming from the control board. Put the other probe on #M5. This is the wire comming from the Neutral side of the power source (the cord). You shouldn't have any voltage present. Push the start switch and you should get a reading of 120 VAC. Results: No volts=Replace control board. 120 VAC=Replace motor.
I just found this wire diagram. Should be the same as yours.
| Sears Kenmore Refrigerator Whirlpool - Condensor Motor attempts start up | danul | Sears Kenmore | 4 | April 7th, 2008 01:27 PM |
| Frigidaire Dryer won't start without a "push" | web | Frigidaire/Electrolux | 0 | October 15th, 2007 06:30 AM |
| motor, motor control or control board??? | bosshogg | Maytag/Magic Chef/Admiral/Jenn-Air | 5 | June 21st, 2007 10:02 AM |
| GU1200 Noisy Motor | moliver | Whirlpool | 10 | January 31st, 2007 08:45 AM |
| Testing start relay & motor | 2nd Shepherd | Sears Kenmore | 1 | September 26th, 2006 04:06 AM |
