Old August 21st, 2008, 08:19 PM
Papasmithnc is on a distinguished road
Default Dryer won't start.
The Model Number is: FDE336RES1. At least I hope it is. My daughter copied it off.
The dryer worked for one load but when the start button was pushed for the second nothing happened. I checked the breaker, and put an electrical tester at the outlet and could find nothing wrong.
The only life I could detect out of the dryer was a faint sound coming from the timer/control when I pressed the start button.
From what I have read, it could be the motor or, the thermal limiter switch. Any ideas??
Dave in NC
Old August 21st, 2008, 10:34 PM
Hi Dave,
Ohm your thermal limiter for continuity with an ohm meter.
Here's the one for your model, in case you need to order it:
Manufacturer's Part: 134120900
Thermal limiter
Its #36 here:
http://content.searspartsdirect.com/lis_png/PLDM/R0503143-00001.png
Or you can just jump it to see if the dryer will come on.
How to take apart:
Disconnect power first
Unplug the dryer. Get the top up by pushing in on 2 clips on either side as shown in this picture.
Courtesy of:
http://www.applianceaid.com/wwf-howto.html
Old August 22nd, 2008, 11:30 AM
spin the drum- does it turn "easy"? with little resistance? could be the belt- had one yesterday, powered, timer ticking, belt broken(put slightly smaller one on so customer no need wait) and of course i checked all the bases until i noticed belt broken 5 minutes into it.
Old August 25th, 2008, 08:53 PM
Thanks for the help. Next time I get to the beach where this dryer is at, I'll check it out and let you know what I find.
Old September 17th, 2008, 05:05 PM
threefivezero is on a distinguished road
I have a similar problem with my Frigidaire Gallery Dryer. I posted a little more info here:
http://www.applianceblog.com/mainfor...4500#post64500
Kenmore 80 Series Dryer Won't Start brinrach Sears Kenmore 7 February 21st, 2008 05:35 PM
Frigidaire Dryer won't start without a "push" web Frigidaire/Electrolux 0 October 15th, 2007 06:30 AM
Whirlpool dryer will not start... STS1SS Whirlpool/KitchenAid 1 August 24th, 2007 09:56 PM
Help Maytag Dryer MDE9206AYW No Start rvpeddler Maytag/Magic Chef/Admiral/Jenn-Air 9 July 23rd, 2007 01:42 PM
Whirlpool Dryer won't start Model#LEC6646AQ0 birdcam Whirlpool/KitchenAid 4 June 29th, 2007 11:12 PM
