Results 1 to 4 of 4
Thread: Removing front cover...how
    cpyrek1 is offline Premium Member
    Nov 2008
    Miami
    Default Removing front cover...how
    Can someone please assist me in how to remove the front cover of my stackable washer/dryer? Frigidaire model number flxe52rbsb. I know that my drain is clogged, just need to get to it/.
    THanks
    This is from Jeff's site:
    remove these screws and pull down on the front panel to remove it. This is a break down of what you will see, the most common parts of the drive can be accessed from the front.
    The water pump is on the left front side. You can remove the 2 rubber hoses to it and check to see if something is clogging it.
    Here's the water pump for your model:
    Manufacturer's Number: 134051200
    Nov 2008
    Miami
    Default Duh
    Wow, I am a moron. I was loking towards the rear for clips.
    Much appreciated. All fixed.
    Chris
    Glad you got it fixed Chris.
  1. Replies: 0
    Last Post: November 5th, 2007, 06:14 PM
  2. How do I remove FRONT COVER, HOUSING
    By CrackerMan in forum Sears Kenmore
    Last Post: July 17th, 2007, 09:40 AM
  3. How to get front cover off Maytag MAV7258AWW ?
    By dfosbenner in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 12th, 2007, 10:32 AM
  4. Need advice on removing Neptune cover
    By ejmpgh in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 19th, 2007, 12:28 AM
  5. Replacing Bosch Nexxt door gasket
    By diy101 in forum Washers
    Last Post: September 20th, 2006, 12:54 PM
