Old November 10th, 2008, 05:12 PM
jhanna is on a distinguished road
Default [FIXED] compressor fast cycleing
Frigidaire side by side Mod # PLHS267ZCB4,
Compressor clicks on, runs, lines get cool, and in 5-6 seconds clicks off again. Both fans (inside and outside) running. Condensor coils clean. Compressor not too hot to touch, just warm
After 1-2 minutes, repeats itself.
any ideas ??
Old November 10th, 2008, 05:33 PM
Yes, your compressor is bad, you will need it replaced. If your refrigerator is less than 5 yrs. old, then contact Frigidaire and they will send a tech. out to do it for no charge. Parts & Labor are covered for 5 yrs. on sealed systems, which includes the compressor.
I have changed many of these compressors for that same problem.
Old November 10th, 2008, 05:48 PM
could it be frozen coils ? i have not checked yet. this model has a t-stat driven defrost system instead of a mech timer.
i put it in the defrost cycle manually, (5 light switch cycles in 6 seconds). keeping an eye on it now.
Old November 10th, 2008, 06:18 PM
No, because with frosted up evaporator(freezer) coils, the compressor runs continuously.
But do check your evaporator coils, take off the back panel inside your freezer.
If they are frosted up I will be surprised, as thats not common when your compressor won't start.
Old November 11th, 2008, 04:58 AM
Thanks Jake, Entering defrost cycle did not help. Coils not frozen.
I guess I will call for service. Compressor is not something I can do myself.
Old November 11th, 2008, 08:05 AM
Yes, a compressor is something no one can change without a refrigeration license now, due to the EPA laws that went into effect in the mid 90's.
Please keep us posted on the outcome.
Old November 11th, 2008, 06:59 PM
Up and running with new compressor !!!
Thanks for the help.
Old November 11th, 2008, 07:08 PM
Excellent, thanks for the update.
Old November 16th, 2008, 03:09 AM
HVAC Tech
Icehouse is on a distinguished road
A little something in the "tip-jar"
