Old December 18th, 2008, 08:06 PM
der Lump is on a distinguished road
Default Error Codes for Frig LEQ1442ES0 stack dryer not in Tech Data Sheet
The short story:
I have a Frigidaire LEQ1442ES0 stack / front-load dryer, manufactured 04/06 per the tag inside the door. Bought it new at Lowe's.
Dryer is blinking two error codes (62 and then 95) that aren't in the Tech Data Sheet. Anyone know what these codes mean?
Also, I hear an intermittent, low almost sizzling sound.
The full story:
Dryer has been beeping like crazy and now won't run more than 15 secs.
Opened front panel, retrieved Tech Data Sheet, ran diagnostic per instructions.
Dryer returned error codes 62 and 95.
That is, the stack of five lights on the far right (Drying, Cool Down, Clean Lint Filter, etc.) would blink six times, then the single Start button light would blink twice. Then two second pause, then repeat.
Then hit the "Options" button to see any other code.
Then the stack of five lights on the far right (Drying, Cool Down, Clean Lint Filter, etc.) would blink nine times, then the single Start button light would blink five times. Then two second pause, then repeat.
Then hitting the "Options" button, I'd get the 62 code again.
Throughout all of this, I hear an intermittent, low almost sizzling sound.
Neither of these codes is in my Tech Data Sheet.
(I even tried reversing the numbers, in case I got them wrong.
But 26 and 59 also aren't in my Tech Data Sheet.)
Any help would be greatly appreciated.
Old December 18th, 2008, 09:17 PM
Its the control board thats bad, you'll need to replace it.
Part#134484212
Read pages 62-64 it tells how to change it here, you can print it out as well:
http://www.applianceblog.com/manuals...Dryer_2005.pdf
der Lump (August 26th, 2009)
Old August 26th, 2009, 04:46 AM
Thanks. I will order the part and see what happens.
I will also contact Frigidiare.
Old August 26th, 2009, 08:17 AM
Ok, sounds good.
Keep us posted.
Kenmore Dryer 417.94072301 No Heat brimmyhop Sears Kenmore 1 September 28th, 2008 10:46 PM
Kenmore Elite HE3 Tech service sheet emarshbuck Sears Kenmore 1 May 22nd, 2008 08:47 AM
Need Tech sheet for GR673LXSB Chris Wro Whirlpool 3 November 20th, 2007 01:37 PM
