Old December 26th, 2008, 02:56 PM
Kevcules is on a distinguished road
Default [FIXED] drian pump buzzes,won't drain
Hello everyone
I have a 2 year old frigidaire professional series 3 speed dishwasher that won't drain anymore. The drain pump just buzzes a different noise than usual. I've had a similar draining problem at my last house and found a piece of glass had worked it's way down to the drin pump impeller. This new dishwasher problem I'm not quite sure. I took off the inside stuff down to the guts,no big pieces of junk. I removed the drain pump,took it apart and saw nothing really wrong.A little bit of crap in the system but nothing significant. When I started after I had cleaned up what I could , I noticed water start to drain out of the drain motor hose then kind of stall, with the drain motor just buzzing. Why is this happening?
Kevin
Old December 26th, 2008, 03:07 PM
Hi Kevin,
Whats the model# of your dishwasher? Its located inside the door on the right or left side of the upper tub walls.
Old December 26th, 2008, 03:20 PM
Hi Jake
The model number is ... PLD2885RFC0
Old December 26th, 2008, 04:40 PM
Thanks Kevin,
Ok, then if the drain motor is just humming and not pumping the water out, and nothing is jammed in it, then the problem is drain motor bearing is bad.
You'll need to replace the drain motor assembly.
Manufacturer part number 154580301 is RepairClinic item number 1257094
154580301
Old December 27th, 2008, 06:30 AM
Thanks for the info! I find it hard to believe the motor is bad after only 2 years. Is this normal?
Is there any thing I can check that I might have missed? Someone else mentioned the loud solenoid click I should hear when switching from wash to drain, I don't remember hearing that.
Kevin
Old December 27th, 2008, 10:00 AM
Yes, I've seen these drain motors go bad within a year.
I can't think of anything else to check, it seems pretty cut & dry that the problem is the drain motor if its just humming and not turning.
Old December 27th, 2008, 12:39 PM
Sounds good Jake... I'll see what my Canadian vendors can do for me!!
Great Site!
Kevin
Old December 27th, 2008, 05:28 PM
Sounds good Kevin. Keep us posted.
Old December 28th, 2008, 05:43 PM
Well.... I decided to make sure my drain hose was not blocked. I pulled off the connection at the sink drain pipe and noticed some black sludge at the end of the drain hose. It didn't look like it was enough to stop the flow, but it was. I cleaned the end of the hose out and now all seems fine. How does this sludge get by the filters in the dishwasher? Also , I think I see the cause of this hose getting plugged. The place where the hose connects to the drain pipe is clamped to a piece of rubber first, then to a metal spout. I don't think it's connected right. Can you show me a diagram of the proper connection?
Kevin
Old December 28th, 2008, 09:11 PM
Yes Kevin thats connected properly, the sludge just builds up over time.
Glad you found the problem and got it fixed.
Drain pump constantly running sajid753 Maytag/Magic Chef/Admiral/Jenn-Air 3 February 26th, 2010 05:45 PM
HEt3 drain pump flow rate? Barnstang Sears Kenmore 1 September 17th, 2008 09:52 AM
Maytag Quiet Series 300 - drain pump? uncre8tv Maytag/Magic Chef/Admiral/Jenn-Air 9 April 25th, 2008 10:50 PM
Kenmore HE3T 110.42922200 F02, Drain Pump? nowhere Sears Kenmore 1 February 11th, 2007 09:42 AM
Kitchenaid KUDS01DL - drain pump connections jnewell3 KitchenAid 3 June 5th, 2006 11:01 AM
