January 2nd, 2009, 07:41 AM
frigidaire FDB2810LDC1 wont turn on help!!
when the door shuts no lights turn on at all. also i opened up the front and around the dipenser you can see little bit of water residue that got in there. also when it is plugged in the actuator for the dispenser is always in the open position then when i un plug it alwys closes. thats why im thinking it could be the dispenser. hepl please.thank you
January 2nd, 2009, 09:38 AM
Its sounds like your dishwasher isn't getting any power at all if no lights even come on, I would first check your breaker to the dishwasher, then test the voltage with a volt meter were your main power comes into it from the junction box under the front of your dishwasher below your tub.
If that reads 120 volts, then its likely your door latch is broken, thus not making any connection to tell the dishwasher to come on.
Here's the door latch assembly for your model:
Manufacturer's Number: 154529403
154529403
January 2nd, 2009, 11:15 AM
already did that there is power.is there a way to test the latch to make sure?
January 2nd, 2009, 02:51 PM
Yes, you would use a ohm meter to check for continuity of your door latch switch/switches with the power off to your dishwasher and wires removed from the switch/switches.
Your ohm meter should read 0 ohms across the switch/switches.
January 3rd, 2009, 08:25 AM
okay on the switch there is 4 prongs i tested the across where the to blk(power) wires attach and there is conitnuity when the door is closed .and tested when the door is open and it reads the the circuit is open.so im thinking the switch is good. what do you think?
January 3rd, 2009, 09:03 AM
Ok, it sounds good, did you also check for 120 volts at the door switch/switches?
If no lights come on at all with 120 volts to the door switches, I would have to believe your control board is bad.
Here's the tech. data sheet for your model:
ftp://ftp.electrolux-na.com/ProdInfo...4495501ena.pdf
Manufacturer part number 154520901 is RepairClinic item number 1063907
154520901
By Bruce Humphrey in forum Frigidaire/Electrolux
Last Post: November 29th, 2007, 05:25 PM
By drownindebt in forum Frigidaire/Electrolux
Last Post: March 6th, 2007, 12:03 PM
By katinajoan in forum Frigidaire/Electrolux
Last Post: January 10th, 2007, 02:53 PM
By jamesa in forum Frigidaire/Electrolux
Last Post: October 21st, 2006, 12:20 AM
By Caryn in forum Frigidaire/Electrolux
Last Post: July 17th, 2005, 01:53 PM
