Old January 3rd, 2009, 06:38 PM
Tagman886 is on a distinguished road
Default NO Water/No Ice
I have a Frigidaire model FRS26ZRGWC that stopped making Ice and there's no water coming to the door. The water filter was just changed, the water valve is working, I removed the line and pushed the button for water in the door and the water came out of the valve. Any suggestions on this? Also the chilled water container is full of water.
Old January 3rd, 2009, 10:09 PM
Thats odd, if the water inlet valve is working you should be getting water to the dispenser and ice maker. Check your ice maker fill tube to make sure its not frozen.
You may have air in the lines, keep trying the water dispenser, hold it awhile to see if water comes out.
Old January 4th, 2009, 10:58 AM
Jake does this model have 2 valves or just one, I only looked at one on the back right hand side, I have read that some have another valve on the left hand side. The one I checked only has one line coming out. Can you tell me the parts I need to order in the event it has 2 valves?
Old January 4th, 2009, 07:33 PM
Yes Tag this model has 2 in the back of the refrigerator, 1 on each side.
When one is bad, its always best to change both, as they work together.
Here's the water inlet valves for your model:
Manufacturer part number 218859701 is RepairClinic item number 452316
218859701
Manufacturer part number 218832401 is RepairClinic item number 452252
218832401
Old January 4th, 2009, 08:07 PM
Thanks a bunch Jake and Happy New Year.
Tag
Old January 4th, 2009, 09:59 PM
Thanks Tag,
Happy New Year!
Old January 26th, 2009, 12:19 PM
twodrbenz is on a distinguished road
Unhappy FRS26ZNH No water no ice
Hi Tag,
Did replacing both valves fix your problem? I have a FRS26ZNH with the exact same symptoms. No water at door and ice maker.
DJ
Old January 27th, 2009, 06:39 PM
Yes it sure did.
Ice Maker just quit osucowboy Whirlpool 3 January 3rd, 2009 08:15 PM
[FIXED] No Ice Ge Gss25tgmf cdrsteve GE/Hotpoint 5 November 6th, 2008 03:33 PM
Whirlpool ice maker water fill tube and cup freezing up NDS Whirlpool 10 July 26th, 2007 11:23 PM
