Old January 14th, 2009, 05:26 PM
THUNDER BOLT is on a distinguished road
Default [FIXED] Frigidaire dryer won't get hot
My 2 year old Frigidaire electric dryer will tumble but won't heat. I get EA4 as a code. I checked and reset the house circuit breaker, and checked the vent for blockage, still nothing. It's model # AEQB7000EP0
Any help would be appreciated. Thanks Matt
Old January 14th, 2009, 10:49 PM
Ok Matt, you will need to unplug or turn the breaker off to your dryer, then take it apart, this link will show you how:
http://www.applianceaid.com/wwf-howto.html
Then look at your element, you may see a broken element wire.
If a broken heating element wire isn't obvious, You would need a volt/ohm meter to diagnose it:
http://www.applianceaid.com/ww-and-mc.html#e-noheat
Here's the heating element assembly for your model:
Manufacturer's Number: 131553900
Here's also the repair manual for your model you can print out the sections you need to:
http://www.applianceblog.com/manuals...Dryer_2005.pdf
THUNDER BOLT (January 15th, 2009)
Old January 15th, 2009, 02:01 PM
Thanks Jake your a "wife" saver. It was the heating element. Repaired, up and running. Matt
Old January 15th, 2009, 09:14 PM
Excellent, good job fixing it Matt.
Frigidaire Electric Dryer Only Stays Hot For 5-8 Min Its Broke Frigidaire/Electrolux 5 November 4th, 2007 10:37 PM
Frigidaire Crown Dryer Top Gets WAY Hot bin555 Frigidaire/Electrolux 1 April 15th, 2007 12:46 PM
Frigidaire Model FSEC446RHS0 Dryer - Hot but slow to dry! Boozer416 Frigidaire/Electrolux 1 February 10th, 2007 09:07 PM
Whirlpool Dryer gets Warm not Hot, Takes long to Dry jnicosia Whirlpool/KitchenAid 4 August 19th, 2005 08:48 PM
frigidaire galaxy dryer (electrolux) gets too hot HiD Frigidaire/Electrolux 9 June 29th, 2005 05:33 AM
