One afternoon I noticed the Water dispenser had stopped working, The next morning the Fridge side was warm, and the stuff on top shelf of the freezer was thawed. Compressor was hot to the touch. I put the food in another smaller fridge, and unplugged the main fridge ( a Frigidaire GLHS269ZCW4 ).
When I got home from work I plugged it in again, and it started cooling the freezer and fridge, AND dispensing water but that only lasted about 20 minutes before the compressor stopped again... and also the water, Opinions? |
Sounds like your compressor may be bad. You should have a 5 yr. parts & labor warranty on the compressor from Frigidaire. Was the condenser fan that sits next to the compressor running? Jake
Hi, Jake,
yes the condenser fan was running, but I didn't hear that typical compressor sound, but the compressor was hot, but not too hot to be able to keep my hand on it for ten or fifteen seconds. Any chance it was a relay or starter or something else? The odd thing was the water dispenser stopping, and then starting after a cool down. thanks, Caldow |
The way I test the compressor start device is to ohm the 2 terminals on it with an ohm meter for continuity (0-1 ohms), if you get that, then its the compressor thats bad.
Here's the compressor start device for your model: Manufacturer's Number: 241527803 Jake
is there a release clip on the main connector going into the start device?
I mean, I have found the Starter Device, unplugged it from the compressor, extracted the capacitor, but I don't know how to get the starter connector unplugged, do I just reef on it, wiggling back and forth till it pops over those two little tabs ?
thanks, Caldow |
OK Jake,
I just used a screw driver to pry up the connector, then detached the wires from the two terminals. I got no reading with the ohm meter, no conductivity. what does that tell you. Is it the start relay, or capacitor? Thanks again, Caldow |
Ok, then if you got no reading at all on it with the ohm meter, then your start device relay is bad, you will need to order the new one I posted above.
Thanking you in advance,
So the Starter is bad, but I can still use the Capacitor? Also I may have broken the first rule of taking things apart, there were two wires attached to the Starter, a heavy gauge Red, and Blue. I think I kept them in order, the Red going to the " L " terminal, and the Blue going to the " N " terminal ??? Thanks again, Caldow |
Yes, you can use the same capacitor.
Yes, Red to the "L" terminal - Blue to the "N" terminal on the compressor start relay. Just a word of warning: The compressor piston inside the compressor can still be bad even though you ohm tested the compressor terminal pins. So if you install the new compressor start relay and it doesn't fix the problem, then you would definitely need a new compressor. Jake
| [FIXED] Kenmore Side by Side - 106.53532300 - stopped cooling | Condo | Sears Kenmore | 5 | May 5th, 2009 03:21 PM |
| Frigidaire side-by-side fridge side not cooling, but freezer side is | Jason K | Frigidaire/Electrolux | 7 | October 27th, 2006 06:39 PM |
| msd2465ge - Fridge side not cooling | MarkF2 | Maytag/Magic Chef/Admiral/Jenn-Air | 6 | August 31st, 2006 10:43 AM |
| GE Side by Side TFX22ZPBG WW No Cooling | Richard | GE/Hotpoint | 10 | June 29th, 2006 02:57 PM |
| Frigidaire side by side leaking on FF side | sacju | Frigidaire/Electrolux | 3 | October 24th, 2005 11:25 PM |
