Old June 21st, 2009, 06:42 AM
hammlarr is on a distinguished road
Question Auger motor installation
I have a new ice dispenser auger motor to install and before I dive into this blindly; has anyone ever replaced one of these before? If so I would aprreciate your assistance with this.
From what I can see it doesn't look that difficult but I have encountered issues like this before and it's not what you can see but what you can't see that creates problems.
the auger is for a Gallery MN-FRS26ZGEW3
auger motor number 53044625924 (Frigidaire OEM)
Thanks again.
Old June 21st, 2009, 09:25 AM
Where did you buy the auger motor from? Is it just the auger motor separately or the new Auger motor frame assembly? as shown here:
Manufacturer part number 5304462594 is RepairClinic item number 1261523
5304462594
Old June 22nd, 2009, 11:40 AM
Default Part number correction
I purchase item 18 actual Frigidaire OEM part # is 241676202 it is refered to as an AUGER MOTOR for the ice dispenser. Sorry about the mis-information but the number I gave you earlier was what was on the packing list.d it from the appliance zone.
Old June 22nd, 2009, 05:31 PM
Ok, then they sold you a pre-upgraded part, so either you can try to install it or send it back and get the upgraded part I link to above.
If you want to just try to install the auger motor only, all you do is remove the track assembly #49 then auger housing #20 then it will come out, just remove the screws that support both of those parts and remove the electrical connector to the auger housing.
Old July 23rd, 2009, 09:53 PM
PDS PDS is offline
PDS is on a distinguished road
Would that new auger motor assembly work with Frigidaire PLHS269ZCB0?
Old July 23rd, 2009, 11:04 PM
Yes, yours uses the same auger motor, but I don't see the complete assembly for your model.
Manufacturer part number 241676202 is RepairClinic item number 1196610
241676202
KSRS25FTMS01 Auger Motor Replacement daverick KitchenAid 7 March 23rd, 2009 08:50 AM
[FIXED] Ice Maker Auger Problems, Ge Pss26nswcss mechman12867 GE/Hotpoint 10 March 12th, 2009 08:43 AM
Kenmore 80 Series Washer, agitator auger problem Jwait Sears Kenmore 3 July 19th, 2007 10:08 AM
KSCS25FKSS Intermittent Auger Motor Problem haizman KitchenAid 17 October 29th, 2006 09:11 PM
Ice dispenser auger has broken 4 times on GE Profile Arctica ewolf GE/Hotpoint 1 March 6th, 2006 01:07 PM
