Old July 16th, 2009, 09:52 AM
J&T J&T is offline
J&T is on a distinguished road
Default Freezer not Freezing, but still Cold...
I just noticed today that my Freezer is not Freezing...it is cold inside...but not cold enough to freeze....My Model # is lffu1465dw6 . The Compressor is kicking on...so it's not that....not sure what else I can check. Please advise.
Old July 16th, 2009, 10:13 AM
Hi J&T,
Are you a appliance tech? Its ok if you are, we have a few here that post regularly.
What you need to do on this model is take off the lower back panel inside the freezer and see if your evaporator coils are all caked-up in frost to where you can't really see the coils, if thats the case you'll need to turn your defrost timer(located in the back near the compressor) into defrost and give it a few minutes to see if the defrost heater comes on underneath the evaporator coils.
Its #23 here, turn it till it clicks and the compressor will shut off, then its in the defrost cycle:
If the defrost heater doesn't come on then you'll need a volt/ohm meter to test continuity(on OHMS setting) on the defrost thermostat(while frosty) with the freezer unplugged.
Let me know what you find, then we will proceed further.
Old July 16th, 2009, 11:28 AM
J&T J&T is offline
Hey Jake....Actually not really an appliance repairman....but I have been scouring the Classified Ads for good deals on Appliances that I feel I can fix and then re-sell. People giving away or selling cheap items that may not require a lot of money to be invested..... but about my Frigidaire....there was in fact Caked up ICE...and I advanced the Control to put it in Defrost Mode....so how would I prevent this in the future?....do you think my Thermostat is going bad?
Old July 16th, 2009, 01:45 PM
When you moved the defrost timer into the defrost cycle, did the defrost heater come on to start defrosting the evaporator coil?
If so leave in defrost and see how long it takes the defrost timer to come out of defrost and kick the compressor back on again.
J&T (July 16th, 2009)
Kenmore SbS cold spot, freezer cold fridge side not cold like it shoud.. Plz Help Teacher4tc Sears Kenmore 17 June 3rd, 2009 09:40 PM
# FRS26R4CW3 Freezer doesn’t stay cold vinalexnc Frigidaire/Electrolux 2 November 26th, 2007 12:36 PM
freezer cold but not freezing wulf36 Frigidaire/Electrolux 9 May 11th, 2007 07:55 AM
Kenmore Freezer: cold but not freezing Jesse Sears Kenmore 2 September 6th, 2005 09:08 PM
Hotpoint refrigerator not getting cold and freezer not freezing nate GE/Hotpoint 10 August 3rd, 2005 09:11 PM
