Old August 23rd, 2009, 11:34 AM
mlink is on a distinguished road
Default [FIXED] 10 year old Frigidaire Gallery front loader
Frigidaire Gallery fills and drains and runs through cycle, but won't agitate or spin. Makes an unhappy sound while trying to do so. I can turn the drum either way manually. Ideas?
Old August 23rd, 2009, 01:32 PM
Yes, sounds like your motor control board went out, very common when this issue happens.
Whats the model# of your washer? Its located inside the door.
Old August 23rd, 2009, 02:04 PM
Model# FWT647GHSO
Old August 23rd, 2009, 02:15 PM
Here is the motor control board for your model:
Spin control board assembly
All parts come with a 30 day full refund, even if you installed them.
You pull your washer out from the wall, then take off the fill hoses(turn off the water supply first) then take off the back access panel, then you will see it in the back on the left side facing the back. Disconnect the electrical quick connectors to it, then unmount it from the washer base, then install the new one.
Old August 23rd, 2009, 02:21 PM
So, if that turns out not to be the problem, I can send the part back for a refund??
Old August 23rd, 2009, 05:30 PM
Yes, you sure can.
There should be a tech. data sheet in the bottom of your washer on the inside panel once you remove the lower front access panel, it has diagnostics steps to go through to confirm if its the motor speed control board or not as well.
This thread explains more about this problem too:
http://www.applianceblog.com/mainforums/showthread.php?t=1141
The Kenmore 417 model is the exact identical one to yours.
mlink (August 24th, 2009)
Old August 24th, 2009, 04:49 AM
Haha, that thread made me think I should just bite the bullet and buy another washer... I ordered the board though and we'll see what comes of that. Thanks!
Old August 24th, 2009, 08:21 AM
Ok, sounds good.
mlink (September 11th, 2009)
Old September 11th, 2009, 10:26 AM
Thank you, the part you recommended fixed the problem. I was unexpectedly out of town for a couple of weeks, but my husband got the part installed while I was away and had success doing some laundry.
Old September 11th, 2009, 11:32 AM
Excellent mlink, good job.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/frigidaire-electrolux/16357-fixed-10-year-old-frigidaire-gallery-front-loader.html
Posted By For Type Date
Frigidaire on Appliance Blog Forums | BoardReader This thread Refback August 25th, 2009 06:28 AM
Frigidaire front loader RobertK Frigidaire/Electrolux 1 January 13th, 2009 09:27 PM
Frigidaire Front loader no final spin fwt449gfs0 lowbus Frigidaire/Electrolux 5 December 2nd, 2008 10:13 AM
Frigidaire Front Loader Wash Time jsjones Frigidaire/Electrolux 3 September 17th, 2008 09:37 PM
Frigidaire Front Loader Spin Problem Linda0829 Frigidaire/Electrolux 1 November 19th, 2007 10:41 PM
Frigidaire front loader wont start jenbiam Frigidaire/Electrolux 4 November 16th, 2007 04:29 PM
