Old October 21st, 2005, 04:06 PM
sacju is on a distinguished road
Default Frigidaire side by side leaking on FF side
I have a side by side Frigidaire that is about 1 1/2 years old. Daily I find a puddle of water under the FF door and right side. I cannot remove the drain pan (by design) to see where it is coming from. I found the drain hole in the FZ side was blocked by ice. I thawed with hair dryer and saw water run down tube into drain pain and no leaks.
Any ideas? Thanks in advance.
SacJu
Old October 22nd, 2005, 12:30 AM
After you unclogged the freezer drain , the water ran out the tube into the drain pan and you didn't see it leak?
Old October 23rd, 2005, 10:33 PM
Correct. Water drained from tube into pan. I did not see a leak from pan.
Old October 25th, 2005, 01:25 AM
Thats odd, check all of your connections, have someone test the water dispenser while you check the water lines underneath.
GE Monogram side by side leaking at bottom right of door? LosGatos GE/Hotpoint 4 May 28th, 2008 09:53 PM
Frigidaire side by side model #FRS26R4AW7 ailina1213 Frigidaire/Electrolux 3 December 22nd, 2006 11:33 PM
How to replace timer switch on Frigidaire side by side refridgerator Pfaffy Frigidaire/Electrolux 7 June 14th, 2006 11:15 AM
Maytag Side by side leaking jrc0109 Maytag/Magic Chef/Admiral/Jenn-Air 3 October 17th, 2005 12:11 AM
Water leaking from side by side Frigidaire goldmonkeyking Frigidaire/Electrolux 3 August 23rd, 2005 06:03 AM
