Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Like Tree1Likes
Thread: [FIXED] Frigidaire FRS26ZRG no water or ice
    terracore is offline Premium Member
    Oct 2009
    my house
    Default [FIXED] Frigidaire FRS26ZRG no water or ice
    Hello,
    I just bought a home with a Frigidaire FRS26ZRG. I do not know the history of the unit. It does not make ice and when I try to use the water dispenser, I can hear a humming sound but no water comes out. I checked the water supply line and there is definitely water going into the unit as the puddle in my kitchen can attest to. Next time I will bring a bucket.
    I removed the filter and it did not help. I tried using the dispenser with the filter cover removed and nothing happened (except the humming sound). I have read other threads on this forum regarding replacing some valves but before I started ordering parts I wanted to know if there is anything I should try first.
    When replying please take into consideration that while I can take apart and reassemble a supercomputer blindfolded, I have no knowledge or experience with appliances and couldn't tell the difference between a solenoid and a flux capacitor. Please don't mistake my inexperience for being obtuse.
    Regards,
    Steve in Alaska
    Hi Steve,
    Yes, its likely the water inlet valves that are bad, I've replaced alot of these on this model for this same issue.
    I will get you the part#'s and explain where they go, but Your missing 2 letters at the end of your model#
    Here's the results I get:
    FRS26ZRGB0 FRG(V1)
    FRS26ZRGB1 FRG(V1) / REFRIGERATOR
    FRS26ZRGB2 FRG(V2) / REFRIGERATOR
    FRS26ZRGB3 FRG(V1) / REFRIGERATOR
    FRS26ZRGB4 FRG(V1) / REFRIGERATOR
    FRS26ZRGB5 FRG(V1) / REFRIGERATOR
    FRS26ZRGB6 FRG(V2) / REFRIGERATOR
    FRS26ZRGB8 FRG(V1) / SIDE BY SIDE REFRIGERATOR
    FRS26ZRGB9 FRG(V1) / SIDE BY SIDE REFRIGERATOR
    FRS26ZRGBA FRG(V1) / REFRIGERATOR
    FRS26ZRGBB FRG(V1) / REFRIGERATOR
    FRS26ZRGBC FRIGIDAIRE/REFRIGERATOR
    FRS26ZRGD0 FRG(V2)
    FRS26ZRGD1 FRG(V3) / REFRIGERATOR
    FRS26ZRGD2 FRG(V4) / REFRIGERATOR
    FRS26ZRGD3 FRG(V2) / REFRIGERATOR
    FRS26ZRGD4 FRG(V2) / REFRIGERATOR
    FRS26ZRGD5 FRG(V3) / REFRIGERATOR
    FRS26ZRGD6 FRG(V4) / REFRIGERATOR
    FRS26ZRGD8 FRG(V2) / SIDE BY SIDE REFRIGERATOR
    FRS26ZRGD9 FRG(V2) / SIDE BY SIDE REFRIGERATOR
    FRS26ZRGDA FRG(V2) / REFRIGERATOR
    FRS26ZRGDB FRG(V2) / REFRIGERATOR
    FRS26ZRGDC FRIGIDAIRE/REFRIGERATOR
    FRS26ZRGW0 FRG(V3)
    FRS26ZRGW1 FRG(V5) / REFRIGERATOR
    FRS26ZRGW2 FRG(V6) / REFRIGERATOR
    FRS26ZRGW3 FRG(V3) / REFRIGERATOR
    FRS26ZRGW4 FRG(V3) / REFRIGERATOR
    FRS26ZRGW5 FRG(V5) / REFRIGERATOR
    FRS26ZRGW6 FRG(V6) / REFRIGERATOR
    FRS26ZRGW8 FRG(V3) / SIDE BY SIDE REFRIGERATOR
    FRS26ZRGW9 FRG(V3) / SIDE BY SIDE REFRIGERATOR
    FRS26ZRGWA FRG(V3) / REFRIGERATOR
    FRS26ZRGWB FRG(V3) / REFRIGERATOR
    FRS26ZRGWC FRIGIDAIRE/REFRIGERATOR
    36 Record(s) Found
    Please post back the one thats yours.
    The model# tag is located inside the refrigerator section on the upper walls or ceiling.
    Oct 2009
    my house
    Hi Steve,
    FRS26ZRGB0 FRG(V1)
    FRS26ZRGD0 FRG(V2)
    FRS26ZRGW0 FRG(V3)
    36 Record(s) Found
    Since I posted, now a LITTLE water trickles out when I try to get water and the unit has made about a dozen ice cubes. Is it still the valves or is there something else I can try? Also, I looked at the model number (inside the door) and the 2 letters you are refering to are not there. Is there someplace else I should be looking?
    thanks for your help.
    p.s. Is changing the valves something an idiot like I can do?
    Not on the door.
    The model# tag is located INSIDE the refrigerator section on the upper walls or ceiling.
    Yes, you will still need the water inlet valves. Yes, You can do it.
    Oct 2009
    my house
    Not on the door.
    The missing letters are WO
    Here's the secondary water inlet valve for your model you can order:
    Manufacturer's Number: 218658000
    218658000
    Here's the main water inlet valve for your model you can order:
    Manufacturer's Number: 218698900
    218698900
    Oct 2009
    my house
    Default how do I replace them, which go where?
    I'm ready to order the parts but I'm afraid I don't know what to do with them.
    Very simple, they are both located in the back of your refrigerator, pull the refrigerator out from the wall, turn off your water supply, remove the lower access panel, and you should see both, one on one side, the other on the other side.
    Just change them out as you see them installed, they are mounted with 2 screws each to your inner cabinet.
    Wiring and tubing all go in the exact same place as the originals.
    jjhendri is offline Member
    Jan 2007
    Ft lauderdale, FL
    Question I have Model FRS26HF7BQ2 and I'm having a similar problem. I have replace the main water valve. But I'm still not getting any ice. I have look at the inlet tubing for frozen water and I see none. the green line on the back of the fridge does not have any water. Any help would be appreciated. Tried the hair dryer etc. on the coils.
    The arm is in the down position and water is flowing as I can dispense thru the in-door. How long will I have to wait for the icemaker to cycle, to send water to the unit. Installed the new water vale last night about 8pm.
    Then pull the front plastic cover off your ice maker, and turn the gear in the way the arrow points, turn it about 1/4 of a turn, then it should go by itself, then wait a few minutes and see if it puts water in your ice maker before the ejector blades stop.
    Let us know what happens.
  1. Testing ice maker water supply at the solenoid
    By jptl in forum Sears Kenmore
    Last Post: April 21st, 2013, 07:29 PM
  2. Frigidaire water and ice dispenser possessed
    By rbaranski in forum Frigidaire/Electrolux
    Last Post: March 14th, 2011, 10:24 AM
  3. Superba Ice Maker and Water Dispener
    By Jake in forum KitchenAid
  4. frigidaire ice maker leak
    By icemanTO in forum Frigidaire/Electrolux
    Last Post: September 28th, 2008, 07:25 PM
  5. Slow water and ice from frigidaire
    By thefly01 in forum Frigidaire/Electrolux
    Last Post: September 18th, 2006, 12:18 PM
