Old October 18th, 2009, 04:35 PM
terracore is on a distinguished road
Default Frigidaire FRS26ZRG no water or ice
Hello,
I just bought a home with a Frigidaire FRS26ZRG. I do not know the history of the unit. It does not make ice and when I try to use the water dispenser, I can hear a humming sound but no water comes out. I checked the water supply line and there is definitely water going into the unit as the puddle in my kitchen can attest to. Next time I will bring a bucket.
I removed the filter and it did not help. I tried using the dispenser with the filter cover removed and nothing happened (except the humming sound). I have read other threads on this forum regarding replacing some valves but before I started ordering parts I wanted to know if there is anything I should try first.
When replying please take into consideration that while I can take apart and reassemble a supercomputer blindfolded, I have no knowledge or experience with appliances and couldn't tell the difference between a solenoid and a flux capacitor. Please don't mistake my inexperience for being obtuse.
Regards,
Steve in Alaska
Old October 18th, 2009, 07:12 PM
Hi Steve,
Yes, its likely the water inlet valves that are bad, I've replaced alot of these on this model for this same issue.
I will get you the part#'s and explain where they go, but Your missing 2 letters at the end of your model#
Here's the results I get:
FRS26ZRGB0 FRG(V1)
FRS26ZRGB1 FRG(V1) / REFRIGERATOR
FRS26ZRGB2 FRG(V2) / REFRIGERATOR
FRS26ZRGB3 FRG(V1) / REFRIGERATOR
FRS26ZRGB4 FRG(V1) / REFRIGERATOR
FRS26ZRGB5 FRG(V1) / REFRIGERATOR
FRS26ZRGB6 FRG(V2) / REFRIGERATOR
FRS26ZRGB8 FRG(V1) / SIDE BY SIDE REFRIGERATOR
FRS26ZRGB9 FRG(V1) / SIDE BY SIDE REFRIGERATOR
FRS26ZRGBA FRG(V1) / REFRIGERATOR
FRS26ZRGBB FRG(V1) / REFRIGERATOR
FRS26ZRGBC FRIGIDAIRE/REFRIGERATOR
FRS26ZRGD0 FRG(V2)
FRS26ZRGD1 FRG(V3) / REFRIGERATOR
FRS26ZRGD2 FRG(V4) / REFRIGERATOR
FRS26ZRGD3 FRG(V2) / REFRIGERATOR
FRS26ZRGD4 FRG(V2) / REFRIGERATOR
FRS26ZRGD5 FRG(V3) / REFRIGERATOR
FRS26ZRGD6 FRG(V4) / REFRIGERATOR
FRS26ZRGD8 FRG(V2) / SIDE BY SIDE REFRIGERATOR
FRS26ZRGD9 FRG(V2) / SIDE BY SIDE REFRIGERATOR
FRS26ZRGDA FRG(V2) / REFRIGERATOR
FRS26ZRGDB FRG(V2) / REFRIGERATOR
FRS26ZRGDC FRIGIDAIRE/REFRIGERATOR
FRS26ZRGW0 FRG(V3)
FRS26ZRGW1 FRG(V5) / REFRIGERATOR
FRS26ZRGW2 FRG(V6) / REFRIGERATOR
FRS26ZRGW3 FRG(V3) / REFRIGERATOR
FRS26ZRGW4 FRG(V3) / REFRIGERATOR
FRS26ZRGW5 FRG(V5) / REFRIGERATOR
FRS26ZRGW6 FRG(V6) / REFRIGERATOR
FRS26ZRGW8 FRG(V3) / SIDE BY SIDE REFRIGERATOR
FRS26ZRGW9 FRG(V3) / SIDE BY SIDE REFRIGERATOR
FRS26ZRGWA FRG(V3) / REFRIGERATOR
FRS26ZRGWB FRG(V3) / REFRIGERATOR
FRS26ZRGWC FRIGIDAIRE/REFRIGERATOR
36 Record(s) Found
Please post back the one thats yours.
The model# tag is located inside the refrigerator section on the upper walls or ceiling.
Old October 25th, 2009, 10:44 AM
Originally Posted by Jake View Post
Hi Steve,
FRS26ZRGB0 FRG(V1)
FRS26ZRGD0 FRG(V2)
FRS26ZRGW0 FRG(V3)
36 Record(s) Found
Since I posted, now a LITTLE water trickles out when I try to get water and the unit has made about a dozen ice cubes. Is it still the valves or is there something else I can try? Also, I looked at the model number (inside the door) and the 2 letters you are refering to are not there. Is there someplace else I should be looking?
thanks for your help.
p.s. Is changing the valves something an idiot like I can do?
Old October 25th, 2009, 12:51 PM
Not on the door.
The model# tag is located INSIDE the refrigerator section on the upper walls or ceiling.
Yes, you will still need the water inlet valves. Yes, You can do it.
Old November 10th, 2009, 02:26 PM
Not on the door.
The missing letters are WO
Old November 10th, 2009, 04:29 PM
Here's the secondary water inlet valve for your model you can order:
Manufacturer's Number: 218658000
218658000
Here's the main water inlet valve for your model you can order:
Manufacturer's Number: 218698900
218698900
Testing ice maker water supply at the solenoid jptl Sears Kenmore 30 December 19th, 2009 11:00 PM
frigidaire ice maker leak icemanTO Frigidaire/Electrolux 32 September 28th, 2008 06:25 PM
Frigidaire water and ice dispenser possessed rbaranski Frigidaire/Electrolux 3 September 19th, 2006 11:22 PM
Slow water and ice from frigidaire thefly01 Frigidaire/Electrolux 7 September 18th, 2006 11:18 AM
