Old October 29th, 2009, 06:23 PM
RuntPacket is on a distinguished road
Default LTF2140ES Code 59
That is if I'm reading the code correctly I get all vertical LEDS that flash 5 times then the start led flashes 9 times. TD sheet says code 59 is No tacho signal for 3 seconds.
Motor Spins with belt off
Tub Spins by hand.
Troubleshooting says to; Measure windings Pin 1 to 2, 1 to 3 and pin 2 to 3. 4-6 ohms if correct replace speed control board. if not check resistance between pins 4 & 5 (If not 105 to 130ohms replace motor).
They say a picture speaks a thousand words anyone want to show me how I would measure these?
Also I can't find a Speed Control Board listed in parts but I do see Control board, motor is this the same item? Which usally fails 1st the motor or the board?
Old October 30th, 2009, 08:19 AM
Here's a member that had the exact same issue and the main control board fixed it:
417.44152400 E59 "No Tacho"
Here's the main control board for your model you can order:
Manufacturer part number 137005000 is RepairClinic item number 1464889
137005000
3.0 cu.ft. Horizontal Axis Front-Load Washer (Good & Better Models):
www.applianceblog.com/manuals/5995413084_Washer_2004.pdf
Let us how it goes.
Old October 30th, 2009, 09:33 AM
Just realized the extended warranty I bought with this is still active. Time to let someone else do the heavy lifting. Thanks
Old October 30th, 2009, 10:59 AM
Ok, sounds good.
Old November 16th, 2009, 03:16 PM
Quick update.
1st they replaced the pump (which I knew worked fine from the diagnostic testing.)
then they replaced the control panel.
and lastly the Motor speed control.
Just ran the 1st test load and it's shaking it's butt off. Guess what now? that's right the 2 shock absorbers are broke. Calling them tomorrow for those. So far in parts costs they could have replaced the whole unit. So far this extended warranty from lowes has more than paid for it self (1 control panel and heater elment on the dryer).
Old November 16th, 2009, 07:38 PM
Yes, sounds like your getting your money's worth and then some for the extended warranty you purchased.
Here's the shock absorber for your model:
Manufacturer part number 134560410 is RepairClinic item number 1472918
Gemini MER6769BAW Error Code F1-8 MarkP Maytag/Magic Chef/Admiral/Jenn-Air 1 August 11th, 2008 10:01 AM
Amana SxS program code redbeardnmt Amana 8 May 29th, 2008 09:00 AM
FEF388WCCD locked up with F3 trouble code stewarttate Frigidaire/Tappan/Electrolux 7 November 22nd, 2006 09:45 PM
Whirlpool oven error code F3 E2 mlamont Whirlpool 14 January 22nd, 2006 01:18 PM
KitchenAid Range Error code F1:E3 Katy KitchenAid 7 October 18th, 2005 03:50 AM
