Old November 8th, 2009, 02:57 AM
scottzim is on a distinguished road
Default Frigidaire dryer blowing no heat
I received a code of E68 when using the instructions on the dryer tech data sheet. I than proceeded w/ the FUNCTION TEST SEQUENCE and all the buttons and lights and digital displays check out accordingly. But my thermistor reading never goes above 68 degrees. Any suggestions
Scott
It is a frigidaire front load dryer...Model # GLEQ2152ES0
About 4 years old and cleaned regularly
Old November 8th, 2009, 11:46 AM
E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel.
Solution:
Press buttons lightly and release.
Disengage button.
Try doing that first if the error code still shows up, then you'll likely need a new control board assembly.
Manufacturer part#134523200 is RepairClinic item#1154933
Old November 9th, 2009, 03:15 AM
The buttons are not sticking.
Just ordered part...will keep u posted once part arrives.
Scott
Old November 9th, 2009, 09:24 AM
Ok, sounds good Scott.
Old November 11th, 2009, 03:44 PM
Just received control panel and installed. I still am not getting any heat. It has been running for 30 minutes now. I am not receiving any error codes either. Any suggestions?
Old November 11th, 2009, 07:44 PM
Did you test the voltage going into the dryer where the power cord connects to it at the terminal block? You should get 240 volts accross both the outer 2 terminals.
I've seen dryer run and not heat, thus only getting 120 volts to make the motor run but not 240 to make the element heat.
If your getting 240 volts then you will need to unplug or turn the breaker off to your dryer, then take it apart, this link will show you how:
White-West, Frigidaire repair info, how does the dryer come apart, front flides and how to replace them
Then look at your element, you may see a broken element wire.
If a broken heating element wire isn't obvious, You would need a volt/ohm meter to diagnose it:
Frigidaire, White Westinghouse, Magic Chef, Maytag Performa Dryers, common repair info, no heat, noises, how to take apart
Here's the heating element assembly for your model:
Manufacturer's Number: 131553900
Here's also the repair manual for your model you can print out the sections you need to:
http://www.applianceblog.com/manuals...Dryer_2005.pdf
[FIXED] Frigidaire Crown Gas Dryer with heat trouble Frazer Frigidaire/Electrolux 3 October 3rd, 2009 09:05 PM
Kenmore Dryer 417.94072301 No Heat brimmyhop Sears Kenmore 1 September 28th, 2008 10:46 PM
Dryer tumbles but no heat - Frigidaire GLGQ2152ES0 thatguyfromnj Frigidaire/Electrolux 1 December 10th, 2007 12:00 AM
No heat Frigidaire Gas Dryer Bob Garneau Frigidaire/Electrolux 1 August 12th, 2007 09:20 AM
Frigidaire Dryer Heat Issues jakemidd Frigidaire/Electrolux 5 May 24th, 2007 10:53 PM
