Old November 17th, 2009, 04:38 PM
TylerV is on a distinguished road
Default [FIXED] Frigidaire Washer #NMWS336FS1
Recently my washer seems to have issues advancing through the washing cycles. First, it would just occur once in a while, now it seems you can run through one cycle no problem, but then others right after will get stuck on the rinse cycles and you have to manually advance the nob to get it to move to the next stage. Washer is from 2007 and does not seem to have any other issues. What could be the issue? Appreciate any guidance.
Old November 17th, 2009, 06:46 PM
When it gets stuck on the rinse cycle, is it still filling with water? or is the agitator moving in the rinse cycle and the timer won't advance?
Old November 18th, 2009, 04:22 AM
It becomes stuck on the rinse cycle and water just seems to run continuously until you advance the dial.
Old November 18th, 2009, 08:40 AM
Ok, then you have a siphon issue. Either your drain hose is too low or you have it duct taped to your home drain pipe so no air can get in it to stop the siphon.
The drain hose should be as high as the washer before it goes into your home drain pipe.
Let me know what you find.
Old November 19th, 2009, 09:35 AM
Thanks, I'll take a look and do some reconfiguring of the drain tonight and see if that does the trick. I will keep you posted.
Tyler
Old November 19th, 2009, 09:45 AM
Ok, sounds good Tyler.
TylerV (November 23rd, 2009)
Old November 23rd, 2009, 07:12 AM
I did a couple of loads of laundry and that seems to have been the issue. The drain hose was too far down in the drain pipe it was probably pretty close if not sitting in the trap.
I really appreciate your insight in diagnosing this issue. If something else comes up I will make sure to let you know.
Thanks again!
Tyler
Old November 23rd, 2009, 08:44 AM
Excellent Tyler, good job.
Tags
#nwms336fs1, frigidaire, problems advancing, washer
[FIXED] Frigidaire GLTF2940ES1 washer repair question. lharwerth Frigidaire/Electrolux 3 September 1st, 2009 07:03 PM
Frigidaire Washer GLTF2940ES0 Not Working thatguyfromnj Frigidaire/Electrolux 9 April 20th, 2008 05:02 PM
Frigidaire washer won't final spin Cyberman Frigidaire/Electrolux 2 October 27th, 2006 08:07 PM
Frigidaire stacked washer eating belts Stephen Webb Frigidaire/Electrolux 3 October 25th, 2006 09:28 PM
Frigidaire Washer stackable with Kenmore Dryer?? hawai Frigidaire/Electrolux 1 November 22nd, 2005 01:53 PM
