Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: [FIXED] Water Won't Flow Into Icemaker, Water Dispenser OK
  1. #11
    Excellent Chris, good job.
    Yes jm, same thing happens to me too.
    mdazb is offline Premium Member
    Jan 2008
    Nor Cal
    Have the same problem with my Frigidaire # FRS26LF8CS1 . Checked the feed tube for restrictions, all clear. Turned the gear, it went through its cycle but no water came into the maker. Where would I go from here?
    Mark
  3. #13
    Quote Originally Posted by mdazb View Post
    Mark
    Ok, is your water dispenser working good? Lots of pressure coming out? If so, then the problem is likely your water inlet valve, it has a triple solenoid on it that controls water flow.
    When the ice maker cycles, do you hear any kind of a humming sound from the back of your refrigerator from that water inlet valve, its best to pull your refrigerator out from the wall and listen closely while the ice maker is cycling.
    Here's the water inlet valve for your model you can order:
    Manufacturer part#241734301 is RepairClinic item#1259226
    Its located in the back of your refrigerator, your water supply line hooks up to it. You'll need to pull your refrigerator out from the wall, remove the lower back access panel to change it.
    slewfoot1956 is offline Member
    Jan 2011
    NM
    I have the identical problem and will try these solutions in the next day or so. Thanks
  5. #15
    Your welcome, let us know how it goes.
    Jan 2011
    NM
    Hi, Well, I took the line out the back of the icemaker and it was not frozen. Unplugged and removed the valve (easy) and took it to a place here that also sells new ones and they checked it and they said the valve is operating fine.
    Now unknown to me since this happened last week. my wife has been been placing water in it maually and it has been popping out the ice.
    It does say somewhere that after the icemnaking arm is raised to stop working , it can take as much as 24 hours to come around when turned back on? If this is true and she has been raising and lowering the arm???
    Beats me.
  7. #17
    Yes, that is true, just leave it alone for 24 hours and see if it works fine on its own.
    Jan 2011
    NM
    Thanks, I'm going to install it all back in morning and see what happens. Hopefully it will start as mysteriously as it stopped.
  9. #19
    Ok, sounds good.
    Jan 2011
    NM
    http://www.searspartsdirect.com/part...O2028565/00012
    Did a bit of research. Amazing how the y don't put schematics in the owners manual but this is what I have. I reinstalled it all today. Bough a bag of ice and through it in , put a note on the outside of the icemaker warning my wife not to f with it
    I recall you mentioning turning the gear which I see in the diagram. How easy does this front cover come off to get at it?
    Don't see any screws. Pop off? Thanks
  1. kitchen aid superba side by side water dispenser
    By worrywort in forum KitchenAid
    Last Post: February 21st, 2008, 10:38 AM
  2. Replies: 2
    Last Post: March 18th, 2007, 11:52 PM
  3. Kenmore refrigerator water dispenser drips
  4. Replies: 9
    Last Post: January 2nd, 2006, 09:22 AM
  5. Replies: 1
    Last Post: December 31st, 2005, 05:29 PM
