July 13th, 2010, 09:38 AM
Electrolux GLER331AS1 won't spin
Dryer won't spin. Pully and belt are intact. What should I look at next, please? Thank you.
July 13th, 2010, 03:13 PM
So when you start it, any sound at all?
Turn the drum with your hand without clothes, it should turn semi-freely both ways.
Let us know.
July 13th, 2010, 08:38 PM
When I press the "start" switch, I can hear the motor. The drum will not spin.
The drum turns freely by hand in one direction.
July 14th, 2010, 12:42 AM
Ok, if the motor is running and the drum is not, it sounds like the belt broke.
But you need to open your dryer first to see if thats the case.
This link shows how to open your dryer(UNPLUG YOUR DRYER FIRST):
White-West, Frigidaire repair info, how does the dryer come apart, front flides and how to replace them
That drum should turn both ways, so you may have something else going on too. Once you have the drum out, turn the motor pulley or blower wheel both ways.
Here's the belt for your model you can order here:
Manufacturer's Number: 134503600
Let us know.
July 14th, 2010, 07:47 AM
The belt appears to be intact, fastened securely around the drum.
July 14th, 2010, 07:51 AM
I will remove the drum and follow your instructions regarding the pulley and blower wheels. Thank you.
July 14th, 2010, 10:51 AM
Ok, because if you hear the motor running but the drum not turning then its likely a idler pulley issue if the belt isn't broken. If the motor is just humming and not running, then its likely a bad motor.
I open the dryer door, have someone hold the door switch in, then I hold the start button and turn the drum with my hand, if it starts turning on its own, its definitely a bad motor.
Here's the motor for your model, You can order it here:
Manufacturer's Number: 131560100
131560100
By kdierk in forum Sears Kenmore
Last Post: October 17th, 2011, 11:43 AM
By lowbus in forum Frigidaire/Electrolux
Last Post: December 2nd, 2008, 11:13 AM
By soggypants in forum General Appliance Chat
Last Post: June 12th, 2007, 08:13 PM
By DanO in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: August 29th, 2006, 11:09 AM
By jedd in forum Sears Kenmore
Last Post: September 28th, 2005, 09:51 PM
