August 9th, 2010, 08:14 PM
#11
Problem. When dryer ran full cycle today it was empty. After putting in wet clothes, it's back to same problem. Did I just spend close to $200 for a part I did not need? Can I return it?
Thanks.
August 10th, 2010, 01:27 AM
#12
Yes, you can return it, read the packing slip it tells you how.
Then call a tech. to come out, since you don't have a volt/ohm meter to fix the rest of your dryers NO HEAT issue.
August 10th, 2010, 05:09 AM
#13
I do have access to a volt meter.
What is causing the dryer to stop mid cycle?
Thanks for your help.
August 10th, 2010, 02:37 PM
#14
I thought you said the control board fixed that problem?
August 10th, 2010, 02:38 PM
#15
Nevermind, I saw what you said.
Did you do the diagnostics thats listed in the repair manual?
August 10th, 2010, 02:47 PM
#16
I looked and didn't see anything regarding diagnostics. Where can I find it?
Thanks.
August 10th, 2010, 06:09 PM
#17
SECTION F - TROUBLESHOOTING on PAGE 51.
August 10th, 2010, 06:11 PM
#18
You can print those pages out if it helps you, so they will be with you at your dryer while doing this.
August 10th, 2010, 07:09 PM
#19
On my particular model there are no stationary cycles as shown in the repair manual page 13. They spin inside a clear window on the front so there is no way to tell where the 3 o'clock and 2 o'clock positions are. Suggestions?
August 10th, 2010, 08:25 PM
#20
Yes I see what you mean.
That manual seemed to have missed that.
I just located a revised manual for your model, that tells you what to do on the same Page 51, You have the BETTER MODEL
http://frigidaireservicetips.com/pdf...tterModels.pdf
By somegeek in forum Sears Kenmore
Last Post: May 30th, 2010, 02:54 PM
Last Post: September 28th, 2008, 11:46 PM
By wrobins in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: August 14th, 2007, 02:10 PM
By BaerEssentials in forum Sears Kenmore
Last Post: December 26th, 2006, 10:40 PM
By esetlamm in forum Sears Kenmore
Last Post: December 10th, 2005, 04:07 PM
Tags for this Thread
