Results 1 to 8 of 8
Thread: refrigerator door handle is loose
    carlos25 is offline Member
    Mar 2011
    brownsville, texas
    Default refrigerator door handle is loose
    Model Number: EW23SS65HS
    Brand: Electrolux
    hi guys, i have an electrolux side by side, the model number posted is not neccessarily the right one just put one in there, but my fridge looks just like that one. the refrigerator door side handle is loose, i took out the handle and a screw sticks out of the door which i found that is what really loose. i want to take the door apart, take out the gasket and then take the white panel from the inside out. but the panel is "glued" with some kind of yellowish spongie adhesive which i don't know what it is. i can take it apart but don't know what to use to put it back together. i was thinking of putting a nut from the inside to the screw on the outside to make it nice and tight. any suggestions would be greatly appreciated.
    thanks
    Why can't you just tighten that door handle screw?
    You can't take these doors apart if they are glued in place.
    Mar 2011
    brownsville, texas
    i tried but the screw doesn't tighten anymore, i don't kow if the problem is the screw or where it is screws, i guess i can try a different screw just to see if it tightens
    Yes, try a little larger diameter screw that same type.
    Mar 2011
    brownsville, texas
    will try that tonight and post the result tomorrow, thanks
    Ok, sounds good.
    Mar 2011
    brownsville, texas
    i tried yesterday with a larger diameter screw and worked good until i trie puttin the handle over the screw, on the handle there is a little screw that when tighten it screws right into the screw from the refrigerator and that how it tightens. it would not tighten as i used a regular round hed screw, i need more of larger hex head. i will try to look for that kind of screw
    Yes, you will need that type of screw.
  1. Kenmore HE2 problem gasket came loose?
    By spectorequipment in forum Sears Kenmore
    Last Post: December 26th, 2009, 10:10 AM
  2. Kenmore Elite S/S Door handle comes loose
    By Dave0747 in forum Sears Kenmore
    Last Post: December 27th, 2007, 01:51 PM
  3. GE Front Loader noisy/drum loose
    By rriggs9000 in forum GE/Hotpoint
    Last Post: July 28th, 2007, 11:29 AM
  4. I found Skate Plate completely loose, water leak, and big bang.
    By tommmm in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: February 13th, 2007, 11:32 PM
  5. Agitator Loose - should I be concerned?
    By taysue in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 31st, 2005, 08:41 PM
