April 30th, 2011, 01:50 PM
Noisy Spin Cycle - Frigidaire Front Loader
Frigidaire
When my machine reaches the spin cycle, it emits a rather high-pitched, constant whining/scraping noise that sounds like there is contact somewhere with a metal object. I removed the back, manually turned the fly wheel, and determined the sound was coming from the motor, not the drum, and it seemed to be coming from the brushes. I removed the left brush from the motor, turned the flywheel, and the noise seemed to stop.
I removed the right brush, cleaned them, oiled the spring a bit, and cleaned the shaft of the motor where the brushes makes contact. I reassembled everything, ran a cycle and the whining gradually returned.
I'm not a mechanic, so I don't know what a worn brush looks like, but the contact surface was smooth, the spring seemed to be functioning properly. I am thinking the easiest solution is to replace the entire motor . . . but as my history on this forum will prove, my instincts might be wrong! Best I can tell, the motor runs around $120 and I am happy to replace it, unless there might be something obvious to one of you experts that I am missing.
It doesn't look like I can buy brushes manufactured for the existing motor and even those I found would run about $60.00 for a pair . . . and the motor is over 10 years old, so don't have a problem spending the money for a new motor with new brushes.
Anything I might want to check before ordering a new motor?
Thanks, Experts.
April 30th, 2011, 06:58 PM
Yes, it would be the motor then if the tub pulley spins by hand and you don't notice the noise in the tub bearing.
The motor for your model is currently $102 here:
Manufacturer part number 131276200 is RepairClinic item number 406940
May 1st, 2011, 05:23 PM
Thanks, Jake.
This is a GREAT site. And the prices at RepairClinic.com are hard - if not impossible - to beat. Once again, I appreciate your expert guidance, Jake. Keep up the good work.
May 1st, 2011, 07:45 PM
Glad to help, keep us posted.
By scolenyc in forum Frigidaire/Electrolux
Last Post: November 25th, 2010, 09:32 AM
By jsjones in forum Frigidaire/Electrolux Reviews
Last Post: September 22nd, 2009, 04:26 PM
By lowbus in forum Frigidaire/Electrolux
Last Post: December 2nd, 2008, 11:13 AM
By Linda0829 in forum Frigidaire/Electrolux
Last Post: November 19th, 2007, 11:41 PM
By Jeff22866@gmail.com in forum Frigidaire/Electrolux
Last Post: March 20th, 2007, 04:58 PM
