Results 1 to 2 of 2
Thread: Ice Build up in Freezer Bottom
    ecurtner is offline Premium Member
    Mar 2010
    Tomball, Texas
    Default Ice Build up in Freezer Bottom
    Model Number: FRS6HR4HB6
    Brand: Frigidaire
    Starting about two weeks ago I would notice a very small amount of water on the floor below the freezer. When I open the freezer door the 1/2" recessed freezer bottom is filled with ice. I break the ice plate loose with a butter knife and then in 2-3 days it is back again. This has continued like I said for about two weeks. Something is leaking a small amount of water to the freezer bottom. Can you instruct me how to fix this problem?
    Eric
    Hi Eric,
    Yes your defrost drain hole/line is clogged, its located behind the lower back panel inside the freezer on the bottom underneath your evaporator coil.
    You will need a hair dryer and hot water to melt the ice thats covering that hole.
    Then run something down the defrost drain hole.
  1. Ice buildup in freezer prevents draining
    By Chas. in forum Whirlpool/Roper/Estate
    Last Post: November 25th, 2012, 01:00 PM
  2. Replies: 8
    Last Post: October 6th, 2011, 12:17 PM
  3. Ice in bottom of freezer again
    By davehk in forum Frigidaire/Electrolux
    Last Post: July 13th, 2009, 10:07 AM
  4. Bottom Freezer Kenmore Ref. - different ice problem
    By Lakeman in forum Sears Kenmore
    Last Post: October 16th, 2008, 08:58 PM
  5. Kenmore Bottom Freezer filling with ice
    By rsbst19 in forum Sears Kenmore
    Last Post: December 9th, 2007, 07:19 PM
