June 8th, 2011, 10:17 AM
#11
Model FRS26HF7BQ2
Originally Posted by
Ok, then its likely the compressor has gone bad, pull your refrigerator out from the wall and take the lower back access panel off and feel your compressor to see if its warm and vibrating.
Hi Jake, thanks and yes it's hot to the touch and does not look like it's vibrating, fan is running but very warm in the fridge. Looks like time for a new fridge
June 8th, 2011, 11:10 AM
#12
Yes, time to go refrigerator shopping.
Now its very rare to see the compressor start relay go bad on the Frigidaire models, The compressor start relay mounts on the side of the compressor. If you have an ohm meter you can ohm that start relay for continuity, but like I said when I went out on service calls for Frigidaire with this same issue, compressor hot but not running/vibrating it would always be the compressor thats gone bad not the start relay.
June 8th, 2011, 11:50 AM
#13
Model FRS26HF7BQ2
Well was not expecting to spend $$$ but in life nothing is guarantee. So Jake as usual thanks for all the help.
June 8th, 2011, 08:30 PM
#14
Yes, I know what you mean.
Glad to help.
October 23rd, 2012, 05:57 PM
#15
I have the same problem with my Magic chef MCBR1020W model. Is there anything that I can do to get it working? It's door was open overnight and now its warm, both freezer and the lower part. Please help.
October 23rd, 2012, 07:42 PM
#16
pc_123
Did you feel the top of your compressor as well to see if its warm and vibrating?
By bbridges in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: February 3rd, 2011, 06:42 PM
By skywalkr2 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: September 21st, 2009, 10:14 AM
By tcreasman in forum Sears Kenmore
Last Post: May 6th, 2007, 10:21 AM
By rkgrp in forum Sears Kenmore
Last Post: April 4th, 2006, 12:52 PM
By jackaninny in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: December 8th, 2005, 10:11 PM
