Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Frigidaire/Kenmore 417. front load door catches
  1. #11
    mikeschumann is offline Member
    Mar 2006
    MN
    Default Replacing Door Lock
    What is the best way to replace the door lock? Are there any service manuals available to download that describes this procedure?
  2. #12
    Not that I know off, you can buy the Repair Manual Here.
  3. #13
    Fezwick is offline Member
    Nov 2006
    New Berlin, WI
    First of all, thanks for all the great information in this post so far, it's helped out a TON.
    Just wondering if anyone knows where the wiring goes to from the two prong connector on the door latch (where the white plastic rectangular connector is). I found that on my washer, that connector is cracked and probably not completing the circuit for the fast final spin.
    Anyone else have the same problem?
  4. #14
    Jun 2007
    Log
    Default Is top access required?
    Hello
    This information is very useful.
    I have a broken older style lock and have ordered the newer style part with wiring harness on its way in a few days. My machine is stacked and in VERY tight awkward spot.
    My question is will I need access from the top of the machine for the new wiring harness? If so I need to plan ahead to get some physical help to unstack etc.
    I already removed the old lock so I have access from the bottom and through the rubber surround.
    Girvan
  5. #15
    Its been awhile since I changed one of these, does it look like your wire harness comes from the bottom? if so, then you shouldn't need to remove the top.
  6. #16
    Jun 2007
    Log
    Still waiting for the parts. Since the failure wasn not planned we have a backlog of washing! So I fixed the old latch with some minature bolts.
    It might now work for another week or a few years.
    Easy to see why they changed the design and now after 8 years all the nylon parts are brittle.
  1. Kenmore 417 ~ Front Loader Washer ~ water problem
    By washertrouble in forum Sears Kenmore
    Last Post: January 3rd, 2007, 08:48 PM
  2. Front Load model 417 squeaking
    By smcwilliams in forum Sears Kenmore
    Last Post: January 3rd, 2007, 08:46 PM
  3. Frigidaire front load washer sounds sick
    By Seal in forum Frigidaire/Electrolux
    Last Post: October 24th, 2006, 07:18 PM
  4. Whirlpool Duet, Maytag Neptune, Frigidaire Front Load???
    By soundjunkie in forum Whirlpool/KitchenAid/Roper
    Last Post: February 7th, 2006, 04:22 PM
  5. [FIXED] [FIXED] Kenmore 417 Front load washer
    By in forum Sears Kenmore
    Last Post: October 12th, 2005, 09:55 AM
