August 8th, 2011, 06:22 PM
Drain line freezing shut
Frigidaire
Hello,
This unit is just the latest one to give us this problem. We have had many of the similar FRT18 units over the last 6 years give us problems. The drain line in the freezer compartment freezes over completely and then it starts raining inside the refrigerator. I usually thaw the drain tube out and then it is better. A handful of the units do it once to twice a year. Is the there a more permanent fix for this or a reason for this to occur.
Doug
August 9th, 2011, 09:30 AM
Hi Doug,
Did you run anything else down the drain line besides hot water? like a little rotor router snake?
Also run a little bleach through the drain line.
By Oxen72 in forum GE/Hotpoint
Last Post: May 5th, 2013, 02:04 PM
By mugatu00 in forum GE/Hotpoint
Last Post: December 22nd, 2010, 10:44 PM
By GaryJ in forum GE/Hotpoint
Last Post: September 22nd, 2010, 12:03 PM
By jatepper in forum GE/Hotpoint
Last Post: January 29th, 2010, 10:21 AM
By Repair Dave in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: April 4th, 2008, 04:41 PM
