December 23rd, 2011, 06:56 AM
front load washer not draining
Frigidaire
I have a 5 yr old Frigidaire front load washer and I think that the pump is bad. I can hear the pump motor kick on but it's not pumping the water out. My washer uses very little water - maybe 1 1/2 gal. It seems to go through all the wash cycles - just won't pump out the water and go into the spin cycle. Am I on the right track thinking that it's the pump motor?
December 23rd, 2011, 07:09 AM
Remove the access panel on the front of the washer below the door.
Check the hose between the tub and the drain pump for garbage that maybe plugging is up.
If it's not plugged up then replace the pump.
Part # AP4359940
December 23rd, 2011, 08:17 AM
By toeknee in forum GE/Hotpoint
Last Post: March 13th, 2011, 10:49 AM
By socalsampson in forum Sears Kenmore
Last Post: January 13th, 2011, 08:25 PM
By cdavis9697 in forum General Appliance Chat
Last Post: December 13th, 2010, 10:23 PM
By nadeem_najam in forum Washers
Last Post: April 7th, 2010, 05:30 PM
By NERO357 in forum Frigidaire/Electrolux
Last Post: January 4th, 2008, 07:29 AM
