January 4th, 2012, 05:28 PM
Repair Manuals
Electrolux
Less than 1 year
Is there a repair manual available for the electrolux washer? I see a repair manual for 3.0 cu.ft. Horizontal Axis Front-Load Washer (Good & Better Models)and Affinity Horizontal Axis Front-Load Washer (6000 & 7000 Series). Are they the same?
January 4th, 2012, 07:52 PM
The Affinity Horizontal Axis Front-Load Washer (6000 & 7000 Series) would likely be the closest to your model.
January 4th, 2012, 07:54 PM
But if yours is under a yr. old don't work on it, you should have a full 1 yr. warranty.
January 4th, 2012, 07:58 PM
Good call. I might just call the tech out and have them clean out the filter.
January 4th, 2012, 08:08 PM
Is it not draining properly?
I forgot these new models do have the filter in the tub to pump hose.
Manufacturer Number 134640200
January 4th, 2012, 08:19 PM
It's draining fine. I have a coin or two that I would like to clean out. Just doing precaution maintenance to keep the machine running in tip top shape. My wife do laundry several times a week, so it takes a lot of beating.
January 4th, 2012, 11:57 PM
By mat68046 in forum Sears Kenmore
Last Post: November 30th, 2011, 09:03 PM
By speedway in forum Whirlpool/KitchenAid/Roper
Last Post: November 10th, 2011, 02:48 PM
By clawson in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: February 25th, 2011, 04:32 PM
By mikeebee in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: December 7th, 2008, 09:18 PM
By indyattic in forum HVAC
Last Post: August 29th, 2008, 08:53 AM
