January 4th, 2012, 08:07 PM
Mildew built up in bellow/rubber seal
Electrolux
Less than 1 year
Recently, i notice there's a good amount of mildew build up inside the bellow/rubber seal. I am using HE liquid detergent. Normally after every wash the door stay open so whatever moisture that's still inside get air out. I also ran hot normal cycle using the tide washing machine cleaner and the mildew is still there. What's causing the mildew built up in the bellow?
January 5th, 2012, 12:00 AM
If your leaving the door open it shouldn't be building up mildew, I've had my front-loader since 2006 and no mildew smell or build-up at all.
Where is your washer located? In a non-ventilated room?
January 5th, 2012, 03:11 AM
Cleanlyness is the only option for the protection from that mildew . regular cleaning of the sensitive area is the only protection for this
Thaning you
January 5th, 2012, 03:42 AM
It's in the wide open area of the basement, next to the water heater. The basement has no mildew smell.
January 5th, 2012, 10:34 AM
Thats odd, then I really don't know why your washer would be getting that mildew, thats another reason to get Electrolux to come out.
By ginky4 in forum Sears Kenmore
Last Post: August 18th, 2010, 11:29 PM
By Mettinger in forum Sears Kenmore
Last Post: February 11th, 2010, 05:14 PM
By bdl99 in forum Sears Kenmore
Last Post: July 19th, 2009, 10:28 AM
By Deann Sullivan in forum Sears Kenmore
Last Post: March 12th, 2007, 06:47 PM
By rca1000 in forum Sears Kenmore
Last Post: November 8th, 2005, 04:27 AM
