Results 1 to 8 of 8
Thread: water leaking from underneath
    Jmontgom is offline Member
    Jun 2010
    Ma
    Default water leaking from underneath
    Model Number: LTF7000ES0
    Brand: Frigidaire
    Hello everyone my Frigidaire Affinity LTF7000ES0 started leaking the other day. the water is coming out from the underneath in the front right corner. I washed my Carhartt overalls last week and i am thinking that some how it put a hole in the Bellow. On the back of the bellow there are holes every inch and a half or so and on the front you can see where the holes are but the rubber isnt punched all the way through, except for a few. there are 5 that are real close to eachother and then there are a couple here and there. Could this be my problem? If not what could I try next. thank you in advance for any help I can get.
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Jun 2010
    Ma
    So those holes in the bellows are ok?
    Jul 2006
    Is there any way for you to post a couple pictures here so we can take a peak at them?
    Jun 2010
    Ma
    Default photos of bello
    Here is a couple of photos. I am going to try and put it back together and leave the front cover off and see if I can see any water leaking from the pump. I took the pump off first and all of the connections and hoses seemed to be ok. maybe the water is leaking from a seal in the pump itself? thank you for helping me with this issue.
    Attached Thumbnails Attached Thumbnails water leaking from underneath-washer-2.jpg   water leaking from underneath-washer-1.jpg
    Jul 2006
    I don't see anything to make me think it's leaking there. Run it with the lower panel off and see if you can tell where the water is leaking from.
    Door Boot Seal 134728400 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Jun 2010
    Ma
    Thanks for your help Rick, you were right itis leaking from the pump. I am going to order the part now. thanks again for your help.
    Jul 2006
    Anytime! Keep us posted on your progress!
  1. [FIXED] Kenmore front-loader: water leaking underneath
    By ontheroadid in forum Sears Kenmore
    Last Post: November 13th, 2011, 08:20 PM
  2. Whirlpool Duet leaking from underneath
    By thewalshclan in forum Whirlpool/KitchenAid/Roper
    Last Post: September 27th, 2011, 11:37 AM
  3. Dishwasher leaking water from underneath
    By fnolteiii in forum Sears Kenmore
    Last Post: November 11th, 2010, 05:13 PM
  4. Kenmore Cold Spot Leaking Water from Underneath
    By KJDuggan in forum Sears Kenmore
    Last Post: September 23rd, 2007, 07:09 PM
  5. Whirlpool GU1200XTKB0 leaking from underneath
    By tmanis in forum Whirlpool
    Last Post: May 4th, 2007, 10:49 AM
