June 25th, 2012, 04:53 AM
Cooling Problem
Frigidaire
Hello everyone, I was searching for the answer to my question for a couple of days now on this forum, to no avail. I know someone else was had this same problem but could not find the answer on here, so here I go.
My fridge and freezer gets warm after 4-5 days. I unplug it for a day and plug it back in and it works fine for 4-5 days. This can go on for months. Now it is unplugged and waiting to be fixed. The fridge is in the garage.
Any help is appreciated. TIA
June 25th, 2012, 05:54 AM
Any frost on the freezer back wall?
Any strange noises when it quits?
LINK> Refrigerator Not Cold Enough | Appliance Aid
June 25th, 2012, 06:09 AM
No strange noises and I haven't noticed frost on the freezer back walls but I will plug back in today and let you know what I see. Thanks for the help and I will get back to you.
Is there anything else I need to watch while it is coming up to temp?
June 25th, 2012, 07:02 AM
A frost build up can take 5-14 days to slowly build up and choke off the air flow.
Need to be more observant when it quits....what is working, what is not working, etc.
June 25th, 2012, 08:36 AM
June 25th, 2012, 10:28 AM
Plugged the fridge in and it isn't getting cold I can hear something running. Any ideas?
June 25th, 2012, 12:59 PM
Originally Posted by
chazwel
Need to find out what is or is not running....condensor fan motor ( beside the compressor ), compressor itself, evaporator fan motor ( in the freezer ).
Didn't run the 4-5 days this time
June 26th, 2012, 04:44 PM
Nothing is running. I hear a buzz for a second when I plug and unplug it. The inside lights work. Bummer this can't be good.
June 26th, 2012, 06:41 PM
Please recheck that....esp that second 2.
-Might be FRS26ZGEW0 FRS26ZGEW1 FRS26ZGEW2 FRS26ZGEW3 FRSZ62GEW4
Inside or outside of the refrigerator?
June 27th, 2012, 04:35 AM
Inside the fridge, in the back. I will check numbers when I get home and post. Thanks.
By MIKEINSTL in forum Sears Kenmore
Last Post: May 16th, 2012, 01:39 PM
By JS239 in forum GE/Hotpoint
Last Post: September 8th, 2011, 03:26 PM
By Odysseus in forum GE/Hotpoint
Last Post: March 1st, 2011, 10:48 PM
By rayvera in forum KitchenAid
Last Post: August 16th, 2009, 06:21 PM
By rewy in forum Frigidaire/Electrolux
Last Post: November 19th, 2008, 05:42 PM
