Results 1 to 2 of 2
Thread: Leaky Fridge
    housedoc is offline Member
    Jul 2012
    illinois
    Default Leaky Fridge
    Model Number: FRS6LF7JS5
    Brand: Frigidaire
    Greetings, I have a Frigidaire side by side fridge M#FRS6LF7JS5 which has been leaking water from the inside/top of the fridge side. I thought that it could be the filter but it actually appears to be dry around the 0-ring connections. Can't say the same for everything else though. In the past I have had issues with the water inlet on the freezer side but that has been repaired. I still do not like the noise that I hear when unit calls for water but nothing appears to be leaking on floor or lower case. Any suggestions appreciated. Thanks, housedoc
    Check to make sure your filter itself isn't cracked, another member reported their's was.
    Here's the filter for your model you can order:
    Manufacturer's Number: WF2CB
    WF2CB
  1. Leaky Ice Maker
    By crhead in forum Frigidaire/Electrolux
    Last Post: March 13th, 2011, 05:45 PM
  2. another leaky 665
    By spunknugget in forum Sears Kenmore
    Last Post: April 23rd, 2007, 10:31 AM
  3. Leaky KUDD210T1(KDB-21?)
    By benstiles in forum KitchenAid
    Last Post: March 1st, 2007, 08:58 AM
  4. Leaky Gasket
    By Goliath in forum GE/Hotpoint
    Last Post: December 15th, 2006, 12:12 AM
  5. Leaky GE
    By duckwasher in forum GE/Hotpoint
    Last Post: January 14th, 2006, 01:45 PM
