Old June 16th, 2006, 04:20 PM
apachebeer is on a distinguished road
Default Frigidaire stacked top load washer/dryer, won't spin
Hello, I have a Frigidaire stacked top load washer/dryer
Model # FEx831CSO It's fairly new, maybe 2 years old.
The washer will fill and empty fine but whenever the tub motor is supposed to go on (ie spin or agitate) the motor makes a soft hum for 15 seconds then the over heat protection must trip, the whole show stalls there.
If I take the belt off the transmission spins freely in either direction. Then with the belt off, if I turn the timer to a spot where the tub motor is supposed to go on, the tub motor just hums until the heat protection triggers. If when the tub motor first tries to start I spin the drive pulley on the motor it will start up running normally. There seems to be 120 volts on the m5 wire on both sides of the start capacitor to ground. Is this likely the motor or is there a way to test the motor controller outputs definitively.
Thanks, Jeff
Old June 16th, 2006, 08:39 PM
-Sounds- like it.
FEx831CSO
FEX831CS0
Motor
Read the wire diagram and/or add a test cord directly to the motor harness and plug into the wall outlet as a test to eliminate the controls to try the motor only.
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Maytag top load intermittent no spin donPop Maytag/Magic Chef/Admiral/Jenn-Air 7 August 29th, 2007 10:46 PM
Frigidaire Top Load Stacked Washer Leaking DanM Washers 9 May 14th, 2007 09:40 AM
Frigidaire FEX831CSO (washer/dryer combo) spin problem solswold Frigidaire/Electrolux 3 February 12th, 2007 04:22 PM
Frigidaire stacked top load washer/dryer, won't drain/spin monsoon Frigidaire/Electrolux 11 July 25th, 2006 05:39 PM
Frigidaire front load washer won't agitate or spin bigwilliecrash Frigidaire/Electrolux 1 March 14th, 2006 03:54 PM
