Results 1 to 6 of 6
Thread: Slow water dispenser
    Tommills is offline Member
    Jul 2006
    Rocklin,CA
    Default Slow water dispenser
    Hi, our Frigidaire fridge Freeze has a water dispenser. I have changed the filter twice, ran it without the filter and the water flow is very slow. I have checked the water pressure and there is more than enough pressure, I checked this at the end of the flexable hose from the wall to the Fridge. Can you assist in what to do next, I am at a loss. Thanks... Tom...
    Whats the model# of your refrigerator?
    Jul 2006
    Rocklin,CA
    HI, the model is FRS26ZRF, side by side Fridge/Freezer. Thanks
    Its possible your water valves are going bad on your refrigerator.
    joerao is offline Member
    Jan 2007
    Seatte,WA
    Default Same problem with new refridge, possible solutions?
    I have the same problem with my 3 month old GLHS68EESB. The water coming out of the dispenser is very low in pressure.
    I've had problems with water lines freezing already, could this also happen to the water lines for the water dispenser?
    The presure coming into the filter is fine (already squirted myself in the face testing it). Not sure how to trace any blockages coming out of the filter.
    Any suggestions before I call A&E for warrentee repair. Just don't want them to come over if its something obvious.
    Thanks in advance.
    If your sure you have good water pressure to your refrigerator's inlet water valve from your water supply line, then its something like a bad water valve, kinked tubing, etc.
    Yes, contact A&E factory service to come out under warranty, since its just 3 months old.
  1. Slow water dispenser
    By Mrjustin in forum Whirlpool/Roper/Estate
    Last Post: May 16th, 2007, 11:23 AM
  2. Water Dispenser SDX26VL
    By jxp_app in forum Amana
    Last Post: February 8th, 2007, 10:49 AM
  3. Kenmore refrigerator water dispenser drips
  4. Frigidaire SxS water dispenser is dripping water
    By batman in forum Frigidaire/Electrolux
    Last Post: June 13th, 2006, 11:15 AM
  5. Replies: 9
    Last Post: January 2nd, 2006, 09:22 AM
