Old May 23rd, 2005, 07:16 AM
tyoung is on a distinguished road
Post imported post
Our ~10 year old Frigidair Gallery side-by-side leaks water into the bottom of the freezer section.
It's much like many of the similiar posts in the forum where a large block of ice forms on the bottom of the freezer and water slowly leaks out the front onto the floor.
I looked at the diagrams for clearing drain plugs but I can't seem to find the drain system on my fridge. Here are the specs:
Frigidaire Gallery Side By Side
Model FRS28XGCW0
WCI Canada
Manufactured 03-95
Thanks for your help!
Old May 23rd, 2005, 07:23 AM
Post imported post
If this helps I found this page with a google search:
LINK > Exploded Parts Views
Edited formatting of link
Old May 23rd, 2005, 10:33 AM
Post imported post
Plugged/restricted defrost drain is very possible.
**I looked at the diagrams for clearing drain plugs but I can't seem to find the drain system on my fridge.**
It starts below the evaporator on the drip tray....#64 to the base under the compressor #22.
http://www.applianceaid.com/frig_leaking.html- Some leaking inside tips.
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old May 24th, 2005, 10:33 AM
Dan O.'s Avatar
Post imported post
jeff1 wrote:
It starts below the evaporator drip tray...
Similar to the "Evap Drain" note in
this picture of a Maytag model.
(BTW. The rear interior freezer back panel
has been already removed in the picture)
JFYI
Dan O.
Appliance411.com
=D~~~~~~
Frigidaire Gallery Side by Side flooded kitchen sandalwood36 Frigidaire/Electrolux 4 January 26th, 2007 10:30 AM
Frigidaire Side by side:Ice ok, water leaks when pushed garret Frigidaire/Electrolux 4 August 2nd, 2006 05:12 PM
Frigidaire FRS28ZRG leaks water Orlin Frigidaire/Electrolux 1 May 7th, 2006 10:44 PM
Frigidaire frs26lf8csn Leaks from Water Filter anggav Frigidaire/Electrolux 5 October 17th, 2005 01:14 PM
frigidaire gallery - no water patty1986 Frigidaire/Electrolux 1 October 16th, 2005 09:59 PM
