Results 1 to 5 of 5
Thread: Frigidaire Crown Series Model FDE323RGS1 Won't Run (Buzzing Sound)
    PMAC is offline Member
    Dec 2006
    Missouri
    Default Frigidaire Crown Series Model FDE323RGS1 Won't Run (Buzzing Sound)
    I was drying a load of clothes tonight and when I went down to take them out the dryer had stopped. I tried to restart it and heard a "buzzing" sound but the dryer won't start. Any ideas?
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    Sounds like you might have a bad motor. Is the sound comming from where the motor is located? After it cools down, will it start?
    Rick
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Dec 2006
    Missouri
    I did not try to start the dryer this morning, but I will check when I get home from work. The buzzing sound is coming from around the top panel. Doesn't sound like it's coming from the bottom rear of the dryer (where I would suspect the motor is located).
    If it is a bad motor, is it expensive to replace?
    Jul 2006
    Did you try the timer in different cycles? If you push the start button with the timer in one of the off positions,the end of cycle buzzer will go off. That buzzer is in the console. I think your motor is ok.
    Rick
    Dec 2006
    Missouri
    Yeah, I tried it in all cycles. The buzzing sound is not very loud, more like the sound of a buzzing transformer. I tried unplugging it to see if it possibly had a master reset, but that didn't work. I wonder if my belt slipped off...
  1. Kenmore 80 Series Model # 110 66822694
    By kingd in forum Sears Kenmore
    Last Post: June 9th, 2006, 12:07 AM
  2. Kenmore side-by-side freezer buzzing sound
    By jbaggins in forum Sears Kenmore
    Last Post: January 10th, 2006, 05:29 PM
  3. amana side by side making a buzzing sound
    By indiana in forum Amana
    Last Post: October 12th, 2005, 11:10 PM
  4. AMANA S/S REFRIGERATOR MAKES BUZZING SOUND
    By Grandpa Bob in forum Amana
    Last Post: July 25th, 2005, 04:42 AM
  5. Frigidaire Washer Emits Loud Electronic Buzzing Noise
    By homeboy in forum Frigidaire/Electrolux
    Last Post: June 20th, 2005, 07:14 PM
